Thread: Curved Curtain Wall Revisited
    Moderator mark b's Avatar
    NSW Australia
    1,434
    04:10 PM
    Interesting tip for those who want to go down the Curved Curtain Wall road again.
    1.Create a standard wall make it out of "Glazing - Curtain Wall Glazing" material (or any glass material)
    2.Draw a CurtaIn Wall with a Radius and you get a straight curtain wall with a highlighted blue line when you select the wall.
    3.Now Tab until you select just the Curtain Wall, substitute your newly made (Normal Wall Type) Curtain Wall and you will have a real Curved Curtain Wall that works as a typical curtain wall, grids, mullions etc..
    Still won't do curved mullions maybe next version??? (Do they exist in the real world ?)
    A real Curtain Wall won't bend only segment, but a normal wall will curve.
ID:	906   Click image for larger version.
ID:	907   Click image for larger version.
    78
    07:10 AM
    I wouldn't count on them. Anyway, I want the pdf output first.
    But the day this happens, we all have switched to catia live building.
    http://www.deelip.com/?p=5487
    I'm pretty sure, it can be done, but $$$$$.
    -rpict
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,549
    09:10 PM
    yep, although you don't see curved extrusions much in commercial work anymore due to the cost I run into them all of the time in retail as in storefronts for mall outlet stores etc. The common curving technique in the US is called stretch forming which is the best way to get a complex aluminum extrusion into a radius with a minimum of deformation. The fabricators have the process so well developed these days that extrusions can maintain snap fits between parts which wasn't the case 10 or 15 years ago.
    Revit Maestro Dimitri Harvalias's Avatar
    January 8, 2011
    128
    09:10 PM
    To build on that tip...
    You can create that wall as you suggest, add a profile(s) for the horizontals and then duplicate the wall as a real curtain wall jwith empty panels and only a vertical mullion pattern.
    This is fine depending on what your end use for the model might be.. If you're looking for accurate quantities then it's probably not the best solution. If you're looking for a 'model' with curved muntins then it might be OK.
  1. Edit Top of Curved Wall
    Last Post: July 16th, 2015, 07:29 PM
  2. Curved Curtain Wall
    By t1shep in forum Architecture - Family Creation
    Last Post: April 1st, 2013, 07:57 PM
  3. curved fin wall
    Last Post: March 1st, 2011, 09:24 PM
