Page 43 of 43 FirstFirst ... 333940414243
Results 421 to 428 of 428
Thread: Revit Formulas for "everyday" usage
  1. #421
    3,194
    09:02 AM
    You don't need the =True stuff. It's even easier than that.
    If your test cases are Booleans, all you need are the parameters themselves
    OR (A,B)
    for example:
    (if (OR (A,B)), "Either is True", Both are False")
    Last edited by DaveP; March 12th, 2019 at 06:37 PM. Reason: oops; ) was in the wrong place
  2. #422
    October 14, 2011
    Boston, MA
    227
    10:02 AM
    for example:
    How I apply what you wrote here in bold. In my scenario, I have three objects each with their own viz yes/no parameter
    What I'd like to happen is,
    if A = True, then B = False
    if C = True, then B = False
    if both A and C = True, then B = True....
    but simultaneously if B = True, both A and C = False
    so far I've got B = True and B = False working
    B = True when = and(A,C)
    B = False when = not(or(A,C))
    So I made two new viz' yes/no parameters. It should work something like this I just can't get the language correct
    A' = something like if(A,B, <True>,<False>) so i'm trying to say if A = True, A' = True. But if B = True, A' = False
    C' would also be if(C,B, <True>,<False>) so if C = True, C' = True. But if B = True, C' = false
    I feel like i'm close but just can't get the viz yes/no to respond to true or false
  3. #423
    3,226
    10:02 AM
    Quote Originally Posted by billiam View Post
    Are you sure about those two requirements together? That would be a circular reference error.
  4. #424
    October 14, 2011
    Boston, MA
    227
    10:02 AM
    right, that's why I'm using A' and C'. which will actually control the viz of the object, sorry the confusion
    A' = if(A,B, <True>,<False>)
    C' = if(C,B, <True>,<False>)
    ..but working
  5. #425
    3,226
    10:02 AM
    Very complex relationships... but, anyway,... This requires Doni49's formula. (see this post for reference). Using his idea, this is possible, like this:
  6. #426
    October 14, 2011
    Boston, MA
    227
    10:02 AM
    turns out I was able to make this work in a much simpler way, it took a bit to figure out the syntax but using A' and B' allowed me to get around the circular chain of references error. See Below
    if A = True, then C = False
    if B = True, then C = False
    if both A and B = True, then C = True....
    simultaneously if C = True, both A' and B' = False
    A (Viz control)
    B (Viz control)
    A' = IF ( and ( A, B ), not (A), A )
    B' = IF ( and ( A, B ), not (B), B)
    C (True) = and ( A, B )
    C (False) = not ( or ( A, B))
    the A' and B' is the parameter that gets applied to the object, A and B are just inputs
  7. #427
    January 2, 2017
    London
    03:02 PM
    I have applied logic to Tags to create some intelligents in the labels. the Tag can determine if the Duct is round or square. Whether a Duct is horizontal or vertical.
    The only addition to the list on the front of this tread is that in Tags - Labels - Calculated Values - Type - Number an If Statement can return a null number by using the square of a negative number.
    I have uploaded some Tags at the link below.
    https://drive.google.com/file/d/1bNjWVe2UH-iEnnI_tpwqF7u1DdcICbn_/view?usp=drivesdk
  8. #428
    April 21, 2016
    04:02 AM
    2 Not allowed! Not allowed!
    Quote Originally Posted by rcgold23 View Post
    how about encoding at call out bubble tag?
    like i want to be like this "000102" but when i press enter it shows only "102"
    are there anyway to make like "000102"
    log() can be used to extract the number of digits from a number. log(100) = 2, log(1000) = 3, and log(108) = 2.033...
    So you can use rounddown(log(<number>)) with a series of nested if statements to get the prefix into a parameter. Then to concatenate it with the original input you would have to use a label in a tag, or concatenate in a schedule.
    if(<number>=0,"00000", if(rounddown(log(<number>))=1,"00000",if(rounddown (log(<number>))=2,"0000",if(rounddown(log(<number> ))=3,"000",if(rounddown(log(<number>))=4,"00",if(r ounddown(log(<number>))=5,"0",""))))))
  1. Fˇrmulas de Revit para el "uso diario"
    By Munkholm in forum Foro Espa˝ol
    Last Post: December 14th, 2017, 06:44 PM
  2. Replies: 3
    Last Post: March 18th, 2016, 11:32 PM
  3. Slab slope discrepancy btw "Slope arrow" and "Define Slope"
    Last Post: May 6th, 2011, 09:39 PM
  4. Revit 2011 - "Black rendering" with Non-English Win XP
    Last Post: January 10th, 2011, 09:15 AM
  5. Replies: 2
    Last Post: January 7th, 2011, 07:19 PM
