Thread: Down Pipe Creation
    March 2, 2011
    15
    04:42 PM
    Down Pipe Creation
    Has anyone done it? Has it worked correctly?
    Im trying to create a parameter based downpipe, rather than individual DP files
    The goal is to have it so i can adjust the width of the eave, the pitch of the roof, and the DP will automatically change to the correct position, included the angle of the turn of the down pipe.
    my issue is i cant seem to define the interesction where the angle of the turn meets the eave width. i always use rerference lince and set everything up from that but im struggling to even get that to work in this instance!
    Has anyone done this or attempted it before? Is it a lost cause?
    New Member johnasb's Avatar
    February 9, 2011
    10:42 PM
    Revit 2012: you can now use Adaptive Components in the project environment.
    Hoping this will could be a good solution for downspouts.
    Kingdom of Denmark
    4,262
    06:42 AM
    Scott.
    Heres a couple of examples that you can have a look at - Notice that most of the parametric dimensions is instance based, so they can be dragged and locked to fit the model
    And like Jonas suggested, ACs could also be an interesting solution in Revit 2012
    June 21, 2011
    6
    12:42 AM
    Perhaps something like this?
    Use: draw downspout using 5 points. Switch types for round versus square. Use radius parameter on an instance basis for sizing.
    Kingdom of Denmark
    4,262
    06:42 AM
    Very nice! Welcome to RFO
    October 28, 2014
    03:42 PM
    Thanks you very much!!
    That's very helpful! Even for 2015, revit still has no down pipes (spouts) in the library, which is a pretty fundamental component in an architectural drafting program.
    January 21, 2016
    12:42 AM
    Quote Originally Posted by Binrock View Post
    Thanks Binrock. very helpful.
    March 4, 2015
    7
    01:42 PM
    Thanks Munkholm + Binrock for sharing your creations.
    Another Revit user wishing plumbing could deal with real world products that arn't all round (rectangular/square downpipes)
  1. bottom elevation tag for pipe
    By swapr78 in forum MEP - General
    Last Post: January 15th, 2015, 05:22 AM
  2. Content Creation
    By iBIM in forum Out There
    Last Post: September 21st, 2012, 08:46 PM
  3. Creating a Pipe system
    By DHelton in forum MEP - General
    Last Post: August 9th, 2011, 02:28 AM
  4. Sloped Pipe Question
    By jhenry58 in forum MEP - General
    Last Post: August 2nd, 2011, 08:57 AM
  5. Wye Connection off sloped main pipe
    By Brett in forum MEP - General
    Last Post: March 14th, 2011, 02:13 PM
