Thread: Site elevation vs. Shared Elevation
    Member KimArndt's Avatar
    February 17, 2011
    Denmark
    172
    07:59 AM
    Hello guys,
    Problem being my project is set up with the internal project elevation at 0, and a "shared elevation" at 15200 being the same elevation.
    Now for the site creation, the elevation of my site is, say 15000, but it seems like the sitepoints are using the internal project elevation (0), which means that the site ends way up.
    I have a feeling that somehow, I need to move the levels (with my entire building) up by 15200, but can't quite seem to get my head around doing so. -Of cause other that selecting all and moving everything up by 15200. I have messed quite a lot with "Project Base Point" and "Survay point - Internal"
    Anyway, would it be easier to link the sitemodel instead of dealing with all of this?
    Kingdom of Denmark
    4,262
    06:59 AM
    Hi Kim.
    You could just create the site way up there, and then move the topo 15200 down when finished. Kinda sucks if you later needs to edit the topo, so Id recommend linking in the topo instead, like you suggested yourself.
    February 17, 2011
    Denmark
    172
    07:59 AM
    Hi Klaus, thanks for the quick response
    Yeah, okay, I see some problems if the need to edit the topo occurs. Other that moving it up and down when wanting to edit it.
    Will try the linking procedure.. Thanks again..
  1. Elevation Tags and Levels
    Last Post: September 28th, 2011, 03:31 PM
  2. Elevation Tags
    By SimAll in forum Architecture and General Revit Questions
    Last Post: April 12th, 2011, 01:03 AM
  3. 3D Elevation resets itself
    By Darryl_S in forum Architecture and General Revit Questions
    Last Post: March 7th, 2011, 04:15 AM
  4. Matchline in elevation
    Last Post: February 10th, 2011, 04:48 PM
  5. Section Head as Elevation
    Last Post: January 18th, 2011, 05:53 PM
