Thread: beam connects to the symbolic lines of the collumn family
    Member Bross's Avatar
    June 16, 2011
    The Netherlands
    138
    03:31 PM
    Hi there,
    i created a collumn with 2d symbolic lines that repersents the centerlines of the profile.
    Only problem is the connecting steel beams will set back automatic, reacting on the 2d lines instead of the geometry of the collumn.
    Any idea on how the add some 2d symbolic lines into a steel collumn family without the conecting beams reacting on those lines?
    I've tried to add ref plane with reference set to "not a reference", tying the 2d lines on these ref plane.This doesn't solve the problem.
    Thanks
    March 21, 2011
    Brisbane
    291
    11:31 PM
    I have had the same problem when adding line work (detail not model lines) to beams and/or column. I wanted to achieve exactly the same as you ie add the Cl.’s for columns. One suggestion was to add the lines to an annotation family which you then load into your column family.
    Cheers,
    johk
    June 16, 2011
    The Netherlands
    138
    03:31 PM
    ok thanks,
    This was a suggestion, but did it work? Did you try? I will try this.
    March 21, 2011
    Brisbane
    291
    11:31 PM
    Yes I did try it.
    The problem I have though is that the symbol doesn’t always show up – as it does when you use drafting lines. I haven’t been able to narrow it down to why but I think it has to with “where” I view/ cut the column ie at the base or viewing from the top.
    jh
    June 16, 2011
    The Netherlands
    138
    03:31 PM
    ok i've tried the solution.
    The beam now connect to the collumn, that part works for so far.
    Is there a familytype that doesn't react on the scale factor when loaded in to the project.
    I need to add a dimension as parameter, where i can set it to be a certain amount of distance.
    for instance i say it has to be 150mm longer than the profile, it has to stay that way, no matter if the scale is 1:100 or 1:20.
    I'll look on to that, if there is a solution.
    Bross
  1. Symbolic Lines Showing up in all views
    By FrenchQuarters in forum Architecture - Family Creation
    Last Post: November 2nd, 2012, 05:13 PM
  2. Symbolic lines
    By amolese in forum Architecture - Family Creation
    Last Post: August 24th, 2012, 06:54 AM
  3. Symbolic Lines & extrusion extents
    By adrianc in forum Structure - Family Creation
    Last Post: May 15th, 2012, 03:40 AM
  4. Symbolic Lines vs Symbols
    Last Post: June 23rd, 2011, 11:19 AM
  5. Symbolic Lines in Framing members
    By Lambolica in forum Structure - Family Creation
    Last Post: May 18th, 2011, 03:34 AM
