Thread: Missing Grid Line 1
    November 16, 2012
    02:35 PM
    Missing Grid Line 1
    I've been searching the internet (and this forum) for about an hour now trying to figure this out. We had a bit of a messy set-up on our project. I am now adding the grid lines in and have had no problem until I try to edit a grid bubble to read "1". An error message continuously appears stating this grid already exists in the project and duplicate grid numbers are not allowed.
    Here is what I've done to try to find this one grid line that is the only one I cannot find:
    In plan, section, elevation and site, I have zoomed extent with the view clip window turned off
    Same as above I have "revealed hidden elements" and again zoomed extent
    Same as above I have checked to ensure no "temporary hide/isolate" commands are active
    All other grids are showing fine, only grid "1" is missing.
    Does anyone have any idea how I may perhaps "purge" this single grid line, or any way you know of that I may not have looked at the drawing to find the missing grid line?
    Thank you!
    November 16, 2012
    02:35 PM
    Still don't know what happened or where it was at, but I solved the issue by selecting one of the grid lines, right clicking, choosing "Select All Instances\In Entire Project", deselecting all of the grids I wanted to keep (every grid I could see) and hitting delete. I was then allowed to number my grid line "1". Wish I had remembered I could do that before posting.
    Rotterdam, South Holland
    3,076
    12:35 AM
    FWIW, do you just have one Grid Type in that project, or might there be two? I have seen a situation where there is a bogus Grid Type, usually called Grid 1, which has no Grid Head assigned. You can easily end up with a very short grid line and no head hiding in plane sight somewhere. Insidious, that.
    Gordon
    May 29, 2018
    25
    05:35 PM
    Create a Grid Schedule and you can find and rename them there
  1. Curtain System grid line rotation
    By tommason in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: October 21st, 2012, 12:19 PM
  2. Custom Callout Head Tag missing middle line
    By nikkiyoung in forum Architecture - Family Creation
    Last Post: August 8th, 2012, 12:16 AM
  3. Grid Line Pullbacks
    Last Post: December 6th, 2011, 06:37 PM
  4. How can i make the curtain system grid being straight line in elevation?
    Last Post: September 23rd, 2011, 09:17 PM
  5. Grid Line Text Issue
    By Yan Naing Bo in forum Structure - General Questions
    Last Post: September 15th, 2011, 03:45 AM
