Results 1 to 9 of 9
Thread: Import shared parameters into an existing shared parameters file
    March 8, 2012
    US
    33
    12:54 PM
    Question Import shared parameters into an existing shared parameters file
    How do I import shared parameters from another discipline into my disciplnes shared parameters file?
    Regards
    Maria
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,563
    11:54 AM
    Quote Originally Posted by Ree View Post
    Regards
    Maria
    If you have a .rvt file that contains those shared parameters you can use Manage/Transfer Project Standards and transfer Project Parameters to your project that uses your shared parameter file. I believe that the imported SPs will be put in a group called Exported Parameters IIRC
    March 8, 2012
    US
    33
    12:54 PM
    I am using my own set of shared parameters and have been given a text file of the other shared parameters I need to import. I do recall something about the Group Exported Parameters. Just the logistiocs of getting them in from the text file. Thanks
    Dave Jones's Avatar
    4,563
    11:54 AM
    There have been several threads about this issue here in RFO. You might start here then do a search for "shared parameters" and you'll come up with lots of hits
    November 19, 2012
    5
    01:54 PM
    Revit Family Tools allows you to compare and merge shared parameter files (and it's free!)
    http://apps.exchange.autodesk.com/RVT/Detail/Index?id=appstore.exchange.autodesk.com%3aRevit-Family-Tools%3aen
    6,361
    02:54 PM
    parameter jerk and whitefeet tools also have functions to copy SP's into families.
    10,895
    01:54 PM
    If youre careful you can do it manually (in Notepad), as long as you modify the group numbers so they dont have any conflicts. Been doing mine that way since i started revit.
    Alex Cunningham's Avatar
    Northern California
    3,576
    11:54 AM
    I would like to emphasize you need to be careful doing this. If you are not good at staring a large bodies of text and finding the one character that's like the other use what Chad is talking about.
    March 8, 2012
    US
    33
    12:54 PM
    Thanks all. I took daves advice and found the links above very helpful. Going through revit was the easiest for me.
    Cheers all
  1. Shared Parameters File
    Last Post: December 4th, 2014, 09:55 PM
  2. Shared Parameters
    By cve60069 in forum Structure - Family Creation
    Last Post: June 11th, 2012, 01:50 PM
  3. Shared Parameters - need assistance
    Last Post: March 7th, 2012, 07:32 PM
  4. Shared Parameters
    By Ali Akbar in forum Structure - General Questions
    Last Post: April 26th, 2011, 08:19 AM
