Thread: Array a line based family inside another line based family
    December 10, 2012
    5
    02:35 AM
    Hello I'm trying to array a line based family inside another line based famili
    (shaders of a brise soleil), but everytime I try to changhe the lenght of the mother family everything explodes...
    any suggestion??
    August 19, 2011
    New Hampshire
    519
    09:35 PM
    Is the line based family using a nested component (shader extrusion) or is the extrusion made in the line based families?
    Arrays like to use nested components if you need to make the shape parametric.
    December 10, 2012
    5
    02:35 AM
    Ok I'll try to explain it a little better
    Thisi is the mother line based family with the structure of the panel done with an array of a rectangular shape
    03_Quindi lo seleziono per il mio sweep
    Here I insert my line based son family, the wing of the brise soleil
    then I lock it to the internal part of the panel
    And as long as it is alone everything works fine, it flexes good
    But when i do an array
    It give me an error, and explodes
    I also tried to put a strong reference in the left and right reference plane of the son family but with no gain
    December 10, 2012
    5
    02:35 AM
    Costruiamo ora la nostra famiglia madre finale, quella che conterr le varie lamelle del nostro brisesoleil e gli garantir la possibilit di rotare.
    01_Creo in una famiglia profilo il profilo che generer la cornice del mio pannello (in questo caso un seplice rettangolo
    [IMG=famigliaprofilo]http://img259.imageshack.us/img259/2531/famigliaprofilo.jpg[/IMG]
    02_Disegno sulla front view, su un piano separato da quello di referenza il percorso del mio sweep ( in questo caso un rettangolo
    [IMG=creolafamigliapannellie]http://img341.imageshack.us/img341/3711/creolafamigliapannellie.png[/IMG]
    [IMG=03sweepselezionepath]http://img9.imageshack.us/img9/7990/03sweepselezionepath.jpg[/IMG]
    04_Ottengo quindi questo solido
    [IMG=risultatoa]http://img707.imageshack.us/img707/7184/risultatoa.png[/IMG]
    05_Che rafiner un pochino per ottenere questo risultato, aggiungendo paini di referenza e quant'altro ritengo possa aiutarmi a realizzare il mio modello in seguito.
    [IMG=05ipaianidiriferimento]http://img824.imageshack.us/img824/2487/05ipaianidiriferimento.jpg[/IMG]
    06_Inserisco quindi la famigli line based dell'ala
    [IMG=06importoala]http://img51.imageshack.us/img51/9928/06importoala.jpg[/IMG]
    07_Provvedo quindi ad allinearla sui bordi interni della mia cornice
    [IMG=07lucchetto]http://img832.imageshack.us/img832/1171/07lucchetto.jpg[/IMG]
    07Bis_Questo il risultato ottenuto
    [IMG=09importala]http://img803.imageshack.us/img803/9494/09importala.jpg[/IMG]
    08_Provo quindi ad effetuare il comando array
    [IMG=arraynellafmaigliaala]http://img811.imageshack.us/img811/5171/arraynellafmaigliaala.jpg[/IMG]
    [IMG=10activatedimension]http://img69.imageshack.us/img69/5417/10activatedimension.jpg[/IMG]
    09_Ottengo per errore quando vado ad allungare la mia famiglia madre
    [IMG=altroerrore]http://img211.imageshack.us/img211/5438/altroerrore.jpg[/IMG]
    10_Anche provando a modificare nella famiglia ala i piani di refernza a destra e a sinistra da normali a Strong continuo ad ottenere errore, ovvero che se modificato dopo l'inserimento l'array mi restituir le dimensioni originarie della famiglia "figlia"
    [IMG=secondaalaconarraynnseg]http://img818.imageshack.us/img818/4381/secondaalaconarraynnseg.jpg[/IMG]
    December 10, 2012
    5
    02:35 AM
    Ops sorry I thought it gave me an error , I did have a more detailed post I'll ink it down here
    http://www.revitforum.org/architectu...e-another.html
    August 19, 2011
    New Hampshire
    519
    09:35 PM
    I'll keep responding to this one, since nobody has responded to the other thread.
    I recreated your family and was also unable to make it flex properly. Create the shader family as a generic model, not as a line-based family. The length parameter in a line-based family does not like to be nested and controlled in the parent family.
  1. Line Based Family nested inside another line based family and arrayed
    By MadMatt in forum Architecture - Family Creation
    Last Post: January 6th, 2013, 05:29 PM
  2. Line Based Family Help
    Last Post: February 1st, 2012, 12:04 AM
  3. line based family to create reveal
    By tweg in forum Architecture - Family Creation
    Last Post: June 16th, 2011, 08:10 PM
  4. Grips in line based detail family.
    By Nurlan in forum Architecture - Family Creation
    Last Post: April 20th, 2011, 09:38 AM
  5. Line Based Generic Family-End Points Problem
    Last Post: January 7th, 2011, 09:02 PM
