Results 1 to 10 of 10
Thread: Ambient Shadows - Brightness
    Member Cyus's Avatar
    July 10, 2012
    London / MK
    499
    09:50 PM
    Is there a way to change the brightness of ambient shadows? I want them lighter than default, but I can't find out how to change it.
    6,389
    04:50 PM
    Open your render settings and hit the Adjust Exposure button. I think that's the setting you want.
Name:	Render Settings.jpg
    April 12, 2011
    Chicago, IL
    542
    03:50 PM
    I'd try messing with the sun and ambient light sliders under the graphic display options for the view. This will affect how everything displays though, not just the ambient shadows.
    billgilliss
    Guest
    The Hidden Line visual style often has very dark ambient shadows, especially for objects far from the camera, and there isn't much you can do about it. But... ambient shadows are much lighter in Shaded views, and the Sun and Ambient Light sliders actually have an effect on the image. I usually just keep them both at 100.
    I use this and then check the "print colors as monochrome" or similar option in the printer setup. Obviously, this won't work if the sheet you are plotting also needs color, but it works well otherwise.
    Member apetitdeux's Avatar
    March 31, 2011
    Lyon, France
    93
    09:50 PM
    I generally use a special type of thin wall, that's only visible in the view I'm working in, and set its transparency, so I can soften the parts of the building that are far from the camera
    (I use an option set, with different options for each view : south elevation, north elevation, view from street and so on...)
    It's quite convenient to bring more depth to elevations - and the option tip gives you enough flexibility to have element models that are visible only in one view
    Member rbcameron1's Avatar
    August 15, 2012
    USA
    191
    03:50 PM
    Shaded view definitely lightens them up. If you do a "white" color override you can get the best of both worlds of Black&White w/ the lightly shaded ambient shadows. Note: I did not apply it to the linked MEP model since those colors remained. This was just for illustration purposes only.
ID:	27807 Click image for larger version.
    October 11, 2016
    08:50 PM
    How did you change the surface colors to all white? Can't find the override...
    2,800
    01:50 PM
    One approach is to use Phase and Phase Filters w Graphic Overrides. Create a new future phase, assign it to the view and then a new Filter with override for the materail. Works well except for glass which it overrides too.
    April 9, 2018
    02:50 PM
    rbcameron1, how did you do this?
    Senior Member biff's Avatar
    June 13, 2011
    Australia
    900
    06:50 AM
    Just how greg described, robert. It is also described in the mastering revit architecture book.
  1. Graphic Display Option (Show Ambient Shadows)
    Last Post: November 26th, 2013, 07:16 PM
  2. Lighter shadows
    By HenryD in forum Rendering and Gallery
    Last Post: December 8th, 2012, 05:37 PM
  3. 2011: Should the ambient occlusion pass show up in plots?
    Last Post: September 17th, 2012, 02:32 PM
  4. Shadows
    Last Post: August 25th, 2011, 06:06 AM
  5. Ambient Occlusion broken in 2012?
    By DoTheBIM in forum Architecture and General Revit Questions
    Last Post: June 30th, 2011, 12:23 AM
