Thread: Duct Connector Configurations
    Junior Member W.Neuok's Avatar
    Tulsa, Oklahoma
    27
    02:25 PM
    For those that create there own mechanical equipment families with duct connectors, attached is a diagram showing the duct connector configurations from Kyle Bernhardt, Author of (http://inside-the-system.typepad.com/my_weblog/)
    Junior Member RevitGarage's Avatar
    December 31, 2010
    Kansas City, MO
    8
    02:25 PM
    Actually, I created that diagram. I'm not sure who marked it up, but I agree with the corrections.
    Tulsa, Oklahoma
    27
    02:25 PM
    Well sorry for the misrecognition it is a great diagram I just wanted to make sure and preserve it. Also I want thank you for sharing this because it has been very helpful in explaining connections to other people with it.
    May 25, 2011
    192
    02:25 PM
    On this topic, if a family has multiple hvac connectors, like a in-line exhaust fan that has a intake side and a exhaust side, which connector would you link the shared parameter for airflow (CFM value)?
    Tulsa, Oklahoma
    27
    02:25 PM
    For an inline exhaust fan we used the exhaust system for both sides but (refering to the diagram of this post) the intake side was setup similar to the return side of the AHU and the exhaust side was similar to the supply.
    May 25, 2011
    192
    02:25 PM
    What I am asking is which connector, inlet or discharge, do you associate the shared paramter Airflow to? I see some families that associate both connectors to the parameter, but this seems like its incorrect and the system would calculate the CFM for the unit twice.
    Tulsa, Oklahoma
    27
    02:25 PM
    Sorry for the delayed responces. Associating the parameter to both connectors would not double the cfm, it just assoicates the parameter to the connectors. This allows you to change the parameter value in the family types dialog and it would apply to the connectors as well.
  1. Flush Side Duct Mounted Grilles
    By W.Neuok in forum MEP - Family Creation
    Last Post: May 29th, 2013, 04:47 PM
  2. Family Connector help
    By Randy_CaS in forum Architecture - Family Creation
    Last Post: June 1st, 2011, 03:50 PM
  3. Placing a Air termal on a duct system
    By BWI-NL in forum MEP - General
    Last Post: April 4th, 2011, 10:57 AM
  4. Two Way Elbow Connector
    By Yogesh in forum MEP - General
    Last Post: March 22nd, 2011, 11:02 AM
  5. How can i create reducing duct elbows?
    Last Post: March 3rd, 2011, 01:24 PM
