Results 1 to 9 of 9
Thread: Kiwi codes family browser2013
    December 24, 2011
    5
    05:47 AM
    Hi friends. I use FB13. I like this add-in. It has many good functions, but I cann't do them. For example...
    1. "Replace selected family with new family even if it is not loaded in the current project".
    How I can do it? Family didn't replace
    My steps...
    2013-01-12_2001 - mixtaper's library
    2. "Drag and drop families from windows explorer onto tabs".
    How I can do it? Family didn't add in FB.
    My steps...
    2013-01-12_2005 - mixtaper's library
    Member KiwiCodes's Avatar
    351
    06:47 PM
    HI Mixtaper.
    First of welcome to the Forum.
    1. Sorry this has changed since the tutorial video was made and I need to redo it. First select the family you want to swap. Then hold down the "Ctrl" Key while you drag/drop the new family into the Revit screen. FB will then swap the families.
    2. It looks as though this function is not working in the current build. I will look into that first thing on Monday Morning and get back to you when I have a fix for that.
    Regards
    December 24, 2011
    5
    05:47 AM
    I tried hold down ctrl. Family replaced 3 times and after sometime I tried again. But in this time I added new famile ( no replace).
    If you need I can record video.
    351
    06:47 PM
    mixtaper.
    I have updated Family Browser and:
    1. Removed the requirement to hold down the "ctrl" key to swap a family. Now all you need to do is select the family/families that you want to swap and then drag/drop a family (within the same category) to swap them out.
    2. I have fixed the drag and drop from windows explorer onto Family Browser.
    Right mouse click on Family Browser and go to -> About and then click on check for updates to get the link for the new version.
    Cheers
    Phillip
    December 24, 2011
    5
    05:47 AM
    Second fix is good.
    But first, I don't know what I did wrong
    I tried on another computer, the same result
    2013-01-20_1604 - mixtaper's library
    December 24, 2011
    5
    05:47 AM
    And How i can delet one famaly from FB&
    351
    06:47 PM
    Quote Originally Posted by mixtaper View Post
    Just remove the family from the folder using Windows explorer or similar and it will disappear from the Family Browser Tab.
    December 24, 2011
    5
    05:47 AM
    Hi. How I can edit cataloge and save txt file in unicode or ANSI format? With UTF-8 I have problem in Russia
    351
    06:47 PM
    HI Mixtaper.
    Good question. I will look into it for you.
    In the future can you also post these questions on our support forum as I watch/get notifications of posts as they happen there, but I don't come to this forum as regularly. - Kiwicodes Support Forum/
  1. Kiwi Codes Solutions Revit Addins Specialists.
    By KiwiCodes in forum Commercial & Free Add-Ins/Extensions
    Last Post: February 24th, 2020, 09:54 PM
  2. Revit OpEd: Kiwi Codes - Project Browser for 2013
    Last Post: March 30th, 2012, 07:15 AM
  3. Family Browser (Kiwi Codes)
    By Munkholm in forum Third party Add-Ins, API and R&D
    Last Post: December 9th, 2011, 08:49 AM
  4. Kiwi Codes Element Renumber FREE
    By mark b in forum Third party Add-Ins, API and R&D
    Last Post: February 14th, 2011, 05:56 PM
