Thread: Variable beam creation
    December 12, 2010
    New York
    322
    06:28 PM
    Is there any possibility to create a variable beam.
    At one end it should be 20x25cm, and at the other end 30x25cm. (b=25, h=20to30cm).
    Thank you,
    Lucian.
    December 20, 2010
    Pune,India
    89
    08:58 PM
    Yes ...you Can...follow the below steps..
    1. File> New> Family
    2. Choose a Structural Framing Template.
    3.Remove the default rectangular mass.
    4.Use a solid Form> Solid Swept Blend
    5.Add a Profile one & assign a parameters (B1 & H1)
    6.Now Add a profile two & Assign a parameters (B2&H2)
    7. Test a family.
    3,202
    10:28 AM
    Yes, it's a matter of creating a structural framing family in where the extrusion of the beam created from the reference level but from the front/back plane, and is constrained to some reference planes that keep the desired heights constant at each end of the beam.
    December 12, 2010
    New York
    322
    06:28 PM
    Thank you very much for the explanation. The problem now is that between the rectangular beams and the sloped one is a tiny space that doesn't fill.
    3,202
    10:28 AM
    Open the beam family again in the family editor. Go to Modify > Family Category and parameters > Structural Material type > Replace "other" for "Concrete". > Load into project.
    December 12, 2010
    New York
    322
    06:28 PM
    Alfredo, that's marvelous. Thank you!
  1. Family Creation Outline?
    By LeanneZ in forum Architecture - Family Creation
    Last Post: June 6th, 2018, 09:22 PM
  2. Down Pipe Creation
    By Scott_CJDH in forum Architecture - Family Creation
    Last Post: October 28th, 2016, 04:54 AM
  3. Content Creation
    By iBIM in forum Out There
    Last Post: September 21st, 2012, 08:46 PM
  4. Beam Poking Through Roof Help
    Last Post: May 6th, 2011, 11:44 AM
  5. Beam and void
    By jbenoit44 in forum Structure - General Questions
    Last Post: March 19th, 2011, 04:58 PM
