Thread: Column Grid Crop Boundary Offset
    January 16, 2013
    4
    06:03 PM
    Question Column Grid Crop Boundary Offset
    I'm having an issue with Revit where the column grid bubbles on my plotted sheets are extending a bit too far and are overlapping the title block. I've been searching this issue all day and tried everything I have found no avail.
    Basically I want to either adjust the default 1" offset between the crop boundary and the bubble, or get the bubbles to move along with my annotation crop boundary. The project is very large with approximately 30 cuts per floor so adjusting the main crop regions won't work - I need to keep the main crop boundary where it is but still be able to move the bubbles in.
    Any help would be greatly appreciated!
    Thanks,
    Andrew
    Member kommunalka's Avatar
    June 1, 2012
    Chicago, IL
    129
    07:03 PM
    Have you tried modifying the column grids in 2D in any of the views... this is view specific and will allow you to have grids with unique extents in each view/ sheet.
    January 16, 2013
    4
    06:03 PM
    Can you elaborate on what you mean by modifying the column grids in 2D? The way my project is set up, I have one large view of each floor where the column grid extends all the way across the building. Then I also have dependent views for each cut, corresponding to each keyplan sector. In one of these views I cant seem to adjust the bubble location except by changing the crop boundary, which I would like to avoid.
    I've attached a pic that shows the bubble location relative to the main crop boundary and annotation crop boundary
    June 1, 2012
    Chicago, IL
    129
    07:03 PM
    If you click on the column grid itself you will see a little text element that will say either 3D or 2D....
    Dragging the column ends with 3D enabled will change the extents of the column grid[s] you are modifying across the project,
    while, dragging the column ends with 2D selected will only change the grid extents in the current view.
    St. Louis, MO
    1,961
    06:03 PM
    You could also try using a Scope Box, and associate your Grids with the Scope Box. When you adjust the extent of the Scope Box, all the Grids will move with it globally (throughout the entire project) automatically. You can still adjust them individually using 2D extents as well. Your Levels can also be controlled by a Scope Box (or Scope Boxes--depending on the size/shape/layout of the building.)
    January 16, 2013
    4
    06:03 PM
    Okay, I just gave that a shot, I think I may be doing something wrong here. In my dependent view there is no 2D/3D option when I select the column grids. In my main full floor view however I do have the option of 2D/3D, but changing between the two doesn't seem to get me anywhere. In both cases I don't have the ability to move any of the bubbles in or out while on my dependent view or the plotted sheet. Annotation crop boundary has no effect in either case. Here's a screenshot of what I see when I select a column line in the dependent view/plotted sheet. All I can do is move the grid lines themselves back and forth, but the bubble stays the same distance from the main crop boundary.
    June 1, 2012
    Chicago, IL
    129
    07:03 PM
    If you turn annotation crop off... you should be able to move the column bubbles closer/ farther away from the building at will...
    are you unable to do this?
    January 16, 2013
    4
    06:03 PM
    Alright, so I finally found out what the problem was. Brace yourselves, because this is going to sound dumb... I couldn't move the bubbles in or out because I was trying to drag the wrong thing. Turns out you can easily move them in and out, but you have to click a BARELY visible blue dot "handle" at the base of the bubble. I was stupidly trying to click and drag the bubble itself.
    Thanks for the assistance kommunalka and cliff. Hopefully someone in the future can learn from my ignorance!
  1. adjusting the column grid of a linked file
    By mthurnauer in forum Architecture and General Revit Questions
    Last Post: July 27th, 2016, 08:15 PM
  2. Graphical Column Schedule Grid Linewights
    By Lambolica in forum Structure - General Questions
    Last Post: December 18th, 2012, 03:05 AM
  3. Column Grid locations between views
    Last Post: August 17th, 2012, 06:13 PM
    Last Post: September 22nd, 2011, 03:50 PM
  5. Light Fixture (Not Column) - located to grid for scheduling and tagging
    By tjgreatrex in forum Architecture and General Revit Questions
    Last Post: September 8th, 2011, 01:28 PM
