Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Dimension to Centerline
  1. #11
    March 5, 2011
    Southern California
    705
    09:40 PM
    bad bad bad bad bad bad bad bad bad bad bad bad bad bad bad bad bad bad bad bad bad bad bad bad bad bad bad bad bad bad bad bad bad bad bad bad bad bad bad bad bad bad bad bad bad bad bad bad bad bad
    +1,000,000
  2. #12
    Alex Cunningham's Avatar
    Northern California
    3,576
    09:40 PM
    We use two dim styles. One with the centerline and one without... however I have no idea why. Because if your family is not using the center line RP setting then even if you use the Center line dim style (unless you override all the dim style settings, but then all the witness lines will be "CL" and that's just dumb) it wont work right. So in your normal every day dim style set the dim style settings to utilize both centerlines and non center lines accordingly.
    I didn't see this posted in the thread but. If you change you line type settings for centerlines you can forgo the CL symbol..... if you would like.
ID:	11133   Click image for larger version.
  3. #13
    May 23, 2011
    Netherlands
    589
    05:40 AM
    Who knows, some day I might even get our designers to design in Revit!
    Tell them they can keep half the upkeep savings on all the other software. For me: pen, paper, Revit and PS, in that order.
  4. #14
    Member Tim Waldock's Avatar
    March 26, 2012
    Sydney, Australia
    59
    02:40 PM
    Does anyone know how to force Revit to put the Centreline symbol in when Revit decides it is not actually a centreline, but you think it is (or just want it to display as such). BTW we have a separate dimension style for Centreline display.
  5. #15
    Northern California
    3,576
    09:40 PM
    Quote Originally Posted by Tim Waldock View Post
    It's it all in the family. The reference planes will determine if the dimension style thinks its a center line or not.
  6. #16
    August 5, 2019
    35
    04:40 AM
    So I was just looking into this because I cannot get the centerline to show up in the dimension. I am dimensioning to a circle, and it snaps to the centerline, but still no centerline on the dimension.
  7. #17
    2,801
    09:40 PM
    The dimension style needs to be setup correctly as well. You can change the centerline symbol, pattern, and tick mark.
  8. #18
    August 5, 2019
    35
    04:40 AM
    See if I have it right. I don't know how to load a centerline symbol, if I need that.
ID:	37280   Click image for larger version.
  9. #19
    2,801
    09:40 PM
    the setup is right... but is the line pattern really a centerline and is the the centerline pattern appropriate of the for the scale/length of witness line?
  10. #20
    August 5, 2019
    35
    04:40 AM
    Yes it's a centerline pattern. I checked it against a Revit family that I know it would identify as a centerline. It pulls a centerline on that family.
    Both dimensions are going to a centerline. One is to a plain circle and the other is to the center of a detail component. When I dim to the circle it makes the centerlines on the circle as it should. But in this case I guess that since the things are at a skewed angle, Revit doesn't get it. No biggie, I'll just have to draw a centerline.
  1. No Centerline Mark if Dim'ing a linked model?
    By David Thigpen in forum Architecture and General Revit Questions
    Last Post: June 23rd, 2019, 03:41 PM
  2. Wall areas from centerline?
    By Nicolai_lilja in forum Architecture and General Revit Questions
    Last Post: November 6th, 2013, 11:51 AM
  3. Centerline node visible in pipe riser
    By amroeder in forum MEP - General
    Last Post: March 1st, 2012, 07:28 PM
  4. temporary dimension (dimension snap) remains large and off screen when zooming in
    By birdnehru in forum Architecture and General Revit Questions
    Last Post: October 27th, 2011, 06:25 PM
  5. Beams Ending Short of Slanted Column Centerline - Help Please
    By Haymaker81 in forum Structure - General Questions
    Last Post: April 26th, 2011, 02:07 PM
