Thread: Can't change family origin point, family loads into project as hidden lines
    September 14, 2012
    84
    08:15 AM
    I'm trying to get the top of the flex bend hose to be the insertion base point for this family (attached)
    But no matter what I do, the base point will be at a 0'-0" elevation, even with the two reference planes defining the origin on the flex bend, so wtf!?!?
    I did try to move all the family elements at once to the default 0,0 origin point, but it won't let me move the elements, why is that?
    Also, the family even if it's shaded in the family editor won't load into the project as anything but hidden lines, what's up with that??
    August 19, 2011
    New Hampshire
    508
    03:15 AM
    (I don't have 2013 installed right now, so I have to just ask questions)
    Did you go into an elevation view and change the origin from the reference level to the flex bend hose point? There's a reference plane on top of the reference level that has the origin defined. Remember you need Z as well as XY.
    Did you assign materials and a material parameter to your geometry?
    September 14, 2012
    84
    08:15 AM
    There are no reference planes in an elevation view below the top of the hose - yet it still sees the origin as the bottom of the cylinder when placed in a project
    I did paint the family as you can see with materials in the family editor, is that a problem?
    August 19, 2011
    New Hampshire
    508
    03:15 AM
    I would recommend actually assigning parameters to your geometry rather than painting. If the option exists in 2013, you can actually paint with parameters, which is also a good choice to do. Painting with just materials makes it difficult to adjust your family later.
    It might be better to use a height parameter to adjust everything rather than use the reference level height adjustment. Bringing in your family will start at an offset of 6' whatever to whatever it is hosted to instead of starting at 0 and flush with the surface. See attached for example.
  1. Family Origin
    Last Post: April 5th, 2013, 02:40 PM
  2. Copying Detail Lines from a Project to a Family
    By mfrietze in forum Architecture and General Revit Questions
    Last Post: October 10th, 2012, 11:55 PM
  3. How to change the material of imported dwg object in a project or family editor?
    Last Post: November 18th, 2011, 09:07 PM
  4. Family Origin not behaving itself...
    Last Post: August 20th, 2011, 12:05 AM
  5. family Origin?
    By Steve Faust in forum Third party Add-Ins, API and R&D
    Last Post: June 24th, 2011, 12:31 AM
