Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: teaching/tutoring Revit
  1.    #21
    3,226
    07:19 PM
    Quote Originally Posted by Goodanswer
    ...Guys what is the relationship between snap increments settings and project units settings?...
    They are separate concepts. Project Units guide dimensions and temporary dimensions among many other values.
    Snap Settings for length and angle manifest in the process of sketching/moving/copying etc. They also are affected by our current zoom factor.
    Sketch a wall using stock snap settings - zoom out you'll find snap settings produce larger increments for length in the dimension value that appears as you move your cursor away from the starting pick point. Zoom in/closer and the dimension values provide smaller increments.
    The stock settings show 4' increments (1200mm) zoomed out and zoomed in quite close offers 1/4" increments. The idea is to provide a reasonable range of values that are useful for sketching based on how "close" we are to the task/work.
  2.    #22
    May 14, 2012
    554
    08:19 PM
    Quote Originally Posted by Marcel Jansen View Post
    Linkedin Learning has a very good standard course for Revit.
    https://www.linkedin.com/learning/re...ial-and-metric
    charge for what's freely available if you know where to look...
    web.archive.org/web/20171209014410/http://revit-detail.blogspot.com
    Depending on where you are in the world (and more specifically, the US), you might have access to Lynda.com through your local library ... for no cost. It's the same as LinkedIn Learning, just a different access portal.
  3.    #23
    Member cganiere's Avatar
    January 5, 2011
    Orange County, California, USA
    224
    07:19 PM
    There are videos in the Revit Help system...
    Last Post: August 29th, 2012, 12:15 PM
