Thread: Roof slab not showing up
    January 27, 2011
    KC,MO
    346
    01:08 PM
    I cannot get my roof assembly to show the proper layers in my 3/4"=1'-0", it only shows the outline. My detail level is set to fine, all other elements show up properly except for my roof. Any thoughts?
    Kingdom of Denmark
    4,262
    06:08 PM
    Hard to tell without having the file to mess with. But it could be related to a bug in 2011, as in this thread.
    The bug should be fixed in 2012, so you could try to update the file... or make a copy of the file, and delete+purge everything unrelated, and upload the file here.
    05:08 PM
    I can't see the picture (it gives me a " you're not logged in" error), but have a look at your Rafter Cut and Fascia Depth. I have seen this behaviour with sloped roofs and a Plumb Cut too.
    January 27, 2011
    KC,MO
    346
    01:08 PM
    Ok so I could only get the file to 6.3mb, so I had to upload it to dropbox.
    http://dl.dropbox.com/u/3060856/roof%20test.rvt
  1. Slab Edges!!!!
    Last Post: May 26th, 2011, 12:01 AM
  2. How to Roof Merge/Join to Lower Roof!!
    By crhdesign in forum Architecture and General Revit Questions
    Last Post: April 30th, 2011, 06:48 AM
  3. Creating floor slab
    Last Post: April 26th, 2011, 07:01 PM
  4. Waffle Slab
    By iitdesigner in forum Architecture and General Revit Questions
    Last Post: April 18th, 2011, 03:13 PM
  5. Roof with different sloping - one roof or individual surfaces?
    By Clogboy in forum Architecture and General Revit Questions
    Last Post: April 9th, 2011, 01:47 PM
