Results 1 to 10 of 13
Thread: Inventor Fusion?
    Member Chadwick17's Avatar
    Fort Collins, CO
    321
    06:24 PM
    Inventor Fusion?
    Anyone know what Inventor Fusion is and why would I use it? Saw that it came with the AutoCAD Arch installation and I'm not sure why.
    Member JeffreyMcGrew's Avatar
    December 10, 2010
    Oakland, ca
    305
    06:24 PM
    Quote Originally Posted by Chadwick17 View Post
    Inventor Fusion is kinda like a marriage between an easy-to-use fast tool like Sketchup and a 'heavier' solid MCAD style modeler like Inventor Suite.
    It's kind of the solid modeling companion to Sketchbook Pro, which is also included.
    We've worked a little bit with it and it's a neat little tool for modeling up ideas quickly once you get used to it. It's good for some industrial design stuff and some early design stuff.
    You could also use it more towards the end of the project if you needed to make solid models of something that's a pain to do in Revit, like custom spider fittings for glass or something along those lines.
    We haven't used it much, however, for we just turn to Revit for 90% of what we do, and the 10% we don't do in Revit we do in Blender instead most of the time. However, if we were designing more mechanical things or things that were going to be fabricated using a different process than what we do now I could see us using it more.
    Fort Collins, CO
    321
    06:24 PM
    Thanks Jeffrey. I'll have to give it a go when I get some free time. Did you say Sketchbook Pro is included as well? I didn't see that one...
    March 5, 2011
    Southern California
    666
    05:24 PM
    December 10, 2010
    Oakland, ca
    305
    06:24 PM
    When I was looking at the Suites, I thought that Sketchbook Pro was included in all of them, but I could totally be wrong there.
    Sketchbook Pro is a great tool. It's something I totally didn't think I needed ("I've got Photoshop, why do I need this little drawing tool?!?") but once I started using it I find I use it all the time now.
    Fort Collins, CO
    321
    06:24 PM
    Yeah, I love Sketchbook Pro. I got it once I got a large Intuos digitizer - and I mostly use it for sketching/drawing in my free time. Even got the Android app of the same name.
    If the entire office had access to it though - that would be sweet.
    March 5, 2011
    Southern California
    666
    05:24 PM
    Sketchbook and Showcase both come with all versions of the new Building Design Suite. So yes, if you change your licensing over to a new Suite, you will get them. If you are on the Revit Suite from last year, you can switch to the Premium level of the Suite and you will also get ALL the Revit's and 3DS Max as well.
    That would be suite.... :-)
    More info at www.Autodesk.com/suites
    Kingdom of Denmark
    4,251
    02:24 AM
    Quote Originally Posted by Scott D Davis View Post
    Agreed! The Suites sure sounds Sweet - Can┤t wait to get the prize tag from my new "local" reseller
    Member ptranberg's Avatar
    April 8, 2011
    Denmark
    66
    03:24 AM
    Did you abandon us??
    "OMG I killed Revit"
    dzatto's Avatar
    5,236
    08:24 PM
    Quote Originally Posted by ptranberg View Post
    OOPS!
