Thread: Beam don't lie with columns, why?
    June 21, 2012
    Tours, France
    1,122
    09:00 AM
    Hi there, I got an issue with columns and beams that drive's me crazy , I'm modeling a steel structure for my project in Revit 2013, but when I try to put my beams these don't lie with the columns, anybody knows why?, I modeled up a couple of beams out of the line of my column and all is ok, but when I change the place of the column and moves near the column the beams automatically changes the dimension the beam see attached image please, any suggestion will be truly appreciated, tnx in advance.Click image for larger version.
    Moderator LeanneZ's Avatar
    Charlotte, NC
    800
    03:00 AM
    I'm trying to understand your question; I'm also trying to recreate your issue to help me understand what the issue is. I'm still not sure I follow.
    In your attached photo, I see you have temporarily hidden some elements. Did you hide column grid lines? They can help you align your beam centerline to the correct place. Or, you can try drawing the centerline of your beam from column to column. Revit is pretty good at automatically snapping to the centers of the columns.
    Or, did you ~want~ an offset on your beam?
    Alex Cunningham's Avatar
    Northern California
    3,576
    12:00 AM
    Go into the Manage Tab in Revit Structure 2013 and find the Structural Setting button. In that windows find Beam Cutback or Beam Offset. Set this to 0"
    June 21, 2012
    Tours, France
    1,122
    09:00 AM
    Hi Alex, tnx a lot!!!!
    June 21, 2012
    Tours, France
    1,122
    09:00 AM
    Hi Alex in addition to your comment I like to say that the reference planes or the work planes are another reason for this behavior within the structural elements when I edited the family and changed the work planes, and after your suggestion the structure works perfect, that's all, best regards.
  1. Hanger Columns
    Last Post: August 9th, 2013, 08:26 AM
  2. Architectural Columns
    Last Post: August 7th, 2012, 10:01 PM
  3. Beams & columns
    Last Post: April 22nd, 2012, 08:10 PM
  4. Slabs at Columns
    Last Post: October 25th, 2011, 08:00 PM
  5. Schedule Columns
    Last Post: January 25th, 2011, 06:21 PM
