Page 1 of 4 1234 LastLast
Results 1 to 10 of 40
Thread: Standard Text Heights
    Senior Member domsib's Avatar
    April 30, 2012
    586
    07:57 AM
    Is there an industry standard text height you guys use when producing drawings?
    I have the BIM standard for Revit on my desk and it says
    Text Height(mm) Plotted full size
    1.8mm - General text, dimensions, notes - used on A3 & A4 drawings
    2.5mm - General text, dimensions notes
    3.5mm - Sub-headings
    5.0mm - Normal titles, drawing numbers
    7.0mm Major Titles
    Does this mean 2.5mm is the standard text height for all drawings at A2, A1 & A0?
    Member cerb0z's Avatar
    July 5, 2011
    Belarus, Minsk
    249
    10:57 AM
    Really, just go with minimum 2,5 mm. Everything lower becomes harder to read.
    R.I.P. MPwuzhere's Avatar
    Las Vegas, NV
    4,864
    11:57 PM
    Standard for us is 3mm for everything...7mm for titles.
    Member need4mospd's Avatar
    March 2, 2011
    Houston
    481
    02:57 AM
    5/64" (~2mm) - Fine print
    3/32" (~2.5mm) - Most text
    1/8" (~3mm) - Sub headings
    1/4" (~6mm) - Titles
    1/2" (~13mm) - Major titles
    Member Cyus's Avatar
    July 10, 2012
    UK
    499
    08:57 AM
    British Standards (I forget the number) says nothing less than 2.5mm. This is a decent standard for us.
    6,387
    03:57 AM
    Quote Originally Posted by need4mospd View Post
    *grumble* stupid imperial measurements
    we use the same sizes as above. 3/32" is a holdover from hand drafting, although I have no clue why lettering was that specific size.
    Member Geert's Avatar
    February 8, 2011
    187
    09:57 AM
    Its a leftover from the day of blueprints and has to do with scalability of drawings.
    Drafting standards in NL used to have 2.5 for minimum height. Type used to be ISO. same as linetypes -13 -18 -25 .5 .7 1mm line widths.
    Member FBlome's Avatar
    Menlo Park, California
    103
    12:57 AM
    US Corp of Engineers at the time (1980's?) required no less than 1/8", all caps. Main reason was to maintain readability at 50% reduction.
    But get this - I just received a plan check comment, from a VERY picky Planning Dept, that my text was too small for 1/2 scale reduction, and requested that I increase the font size. I had just switched to using Calabri which is smaller in height than Arial using 3/32".
    2,796
    05:57 PM
    we use 3.5mm for A1/AO because we often print those sheets at A3 anything smaller becomes hard to read. 2.5mm for A3.
    4,443
    08:57 AM
    2.5mm is far too big for me - it's like easy read for kids - and is a hangover from printing and scaling.
    I personally don't care for making A1 drawings "readable-when-printed-at-A3" because:
    a. they're not made to be critically reviewed at A3 - so recipients need to print it at full scale
    b. if they're only ever going to be used at A3, then the sheet should be designed to be A3 in the first place
    c. internal review of (paper) drawings is wasteful, and pretty much the only reason why we (as in us, not the collective "we") have printers
    d. digitial review (and markup) is far more effective - and allows us to zoom-zoom-zoom to our hearts content.
    As such, I use as low as 1.75mm.
    I can read this quite clearly even on the occasions when printed A1-to-A3, because I go to optician, and I suggest others do when they grumble they can't.
    Quote Originally Posted by Cyus View Post
    The "number" is BS1192. Horrible document. It's also just been supplemented by PAS1192. If you're not an LRUG member on LinkedIn, ask to join, we had a bit of a chat about it recently.
    EDIT
    Quote Originally Posted by FBlome View Post
    This is a v.important factor that is seldom factor with blanket "Thou shalt not use fonts no shorter than X" commandments.
    Because an "open" standard can't/shouldn't directly reference a particular font, it leaves us all to dither over which fonts - and which styles of said fonts we use. Some fonts render larger than others when using pt sizes - and some are simply easier to read than others at fixed (measured) sizes. Equally, some applications enable you to play with lineweight of text and character spacing. And then there are platform differences for native/common fonts. Along with personal/company/state/country/contract preferences for ALL CAPS, Title Case & the dreaded "i'm too cool to use capitals" style.
    All this ensures there is no common truth to these standards - just as they aren't (sadly) with lineweights, hatch patterns, drawing packages, etc.
    Were our industry's to align to these things in an attempt to find parity - we might be better able to get on with actually designing better proposals instead of faffing with fonts.
  1. Non standard, standard projects.
    Last Post: February 12th, 2013, 06:04 PM
  2. Using groups for multi-unit buildings with different floor-to-floor heights
    Last Post: February 12th, 2013, 11:23 AM
  3. Levels (Plan Views) showing at wrong heights. Is this an easy fix?
    By honung in forum Architecture and General Revit Questions
    Last Post: January 4th, 2013, 06:23 PM
  4. How do you create a roof for diffrent Wall heights
    By dlggnation in forum Architecture and General Revit Questions
    Last Post: May 12th, 2011, 08:45 PM
  5. Random Window & door Heights
    Last Post: December 11th, 2010, 08:10 PM
