Thread: Cant Cut Sweep With Void
    Moderator Drew's Avatar
    Perth, Western Australia
    695
    02:37 AM
    Hi Guys / Gals,
    We have created a hosted profile to be used as a flkoor thickening to our slab under internal walls. W have used this profile in a wall sweep. Pick the wall line and the slab thickening is in place. No problem.
    What we ahve found is that we need to cut the thickenings at an angle where the meet a basement wall. We tried to use a void to cut the sweep but the followng error came up.
    Selection cannot be copied.
    Element cannot be copied because it would lose its references.
    why is it trying to be copied? and what references will it lose?
    Any ideas on how we can cut these wall sweeps at angles?
    3,247
    01:37 PM
    A wall sweep can be cut with a model in-place void. Cut Geometry should be used before ending the model in-place.
    Member gpktm's Avatar
    October 22, 2012
    Melbourne, Australia
    150
    04:37 AM
    Question
    I'm having the same problem here. Trying to make a cut on wall sweep, I'm doing the cut inside the Edit in Place and everything works fine, when I click "Finish Model" is giving me the same error and does not allow me to continue. Any suggestions?
    2,842
    04:37 AM
    Try moving the extents of the void beyond the edge of the sweep, use cut before finishing MIP.
    October 29, 2012
    08:37 PM
    I have the same issue.
  1. Void form not creating void.
    By mikey1073 in forum Architecture - Family Creation
    Last Post: December 6th, 2012, 03:13 PM
  2. Void sweep constrain and Oval or Circle shape constrain
    By como in forum Architecture - Family Creation
    Last Post: October 15th, 2012, 02:45 AM
  3. void sweep faces material
    By seb360 in forum Architecture and General Revit Questions
    Last Post: February 6th, 2012, 11:56 PM
  4. void family will not cut wall type with associated sweep
    By tweg in forum Architecture - Family Creation
    Last Post: December 5th, 2011, 09:08 PM
  5. Void Cut Two Walls
    Last Post: August 15th, 2011, 08:13 AM
