Thread: Beam Wall End Cutback
    March 9, 2011
    12
    09:03 PM
    I am trying to figure out why a beam that frames into the end of a wall doesn't cutback properly. The top of wall and top of beam align. Beams that frame into the side of a wall cutback right. So why doesn't it work for the end of the wall. Any thoughts. see attached.
    Nantes, France
    1,381
    06:03 AM
    hi, it may deal with the detection of reference planes for walls faces, and it is not here at the end. try to play a little with a ref. plane perpendicular to wall faces so that the beam cutback.
    March 23, 2011
    44
    12:03 AM
    My understanding is that that is a bug that the factory is aware of, but is not severe enough to warrant any action at this time.
    Member Ben-May's Avatar
    Melbourne,Oz
    305
    03:03 PM
    Definatly a bug, it only happens if you beam is parallel with the walls analytical plane, if you are at a slight angle you will get a cutback
Name:	beam cutback.png
  1. Auto Cavity End Closure and Continuous Cavities
    By mark b in forum Tutorials, Tips & Tricks
    Last Post: October 4th, 2018, 07:41 AM
  2. stretch end of wall specific dimension
    Last Post: November 11th, 2015, 12:10 PM
  3. Beam and void
    By jbenoit44 in forum Structure - General Questions
    Last Post: March 19th, 2011, 04:58 PM
  4. High End Cabinet Families
    By Wadeshuey in forum Architecture and General Revit Questions
    Last Post: February 3rd, 2011, 01:44 AM
  5. Line Based Generic Family-End Points Problem
    Last Post: January 7th, 2011, 10:02 PM
