Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: inserting Point CLOUDS - how ???
  1. #11
    May 29, 2013
    7
    08:00 PM
    Hi Steve I don't know why but neither did Revit 2014 or Recap worked.. So I installed Revit 2013 and changed the same .txt file to .xyz and imported it to Revit 2013, and it worked...Revit indexed the file properly....So I guess the problem is the Revit 2014... Thank you so much for your support
  2. #12
    3,188
    12:00 PM
    Quote Originally Posted by margaridajbarbosa
    Hi Steve I don't know why but neither did Revit 2014 or Recap worked.. So I installed Revit 2013 and changed the same .txt file to .xyz and imported it to Revit 2013, and it worked...Revit indexed the file properly....So I guess the problem is the Revit 2014... Thank you so much for your support...
    It's odd that the most basic format of TXT fails in 2014. Would be free to share that file so I could pass it along to Autodesk? You could create a support request yourself of course but then I'd be interested to play with the file to see what happens.
  3. #13
    May 29, 2013
    7
    08:00 PM
    Hi Steve. To where do you want me to send the .txt?
  4. #14
    3,188
    12:00 PM
    you can use steve at aecadvantage dot com
  1. Georeferenced Point Clouds? right...
    By freeberic in forum Third party Add-Ins, API and R&D
    Last Post: January 29th, 2016, 12:14 PM
  2. Point Clouds in Revit 2012
    By brenehan in forum Architecture and General Revit Questions
    Last Post: July 11th, 2014, 07:55 PM
  3. Kinect Fusion Point Clouds?
    By hclbaumbach in forum Out There
    Last Post: March 11th, 2013, 03:44 PM
  4. Point Clouds in Revit
    By DoTheBIM in forum Architecture and General Revit Questions
    Last Post: September 16th, 2011, 12:16 PM
  5. Revit OpEd: Point Clouds and Worksets
    Last Post: August 11th, 2011, 03:10 PM
