Results 1 to 10 of 12
Thread: Structure error
    June 21, 2012
    Tours, France
    1,062
    06:31 AM
    Structure error
    Hi there, I'm working in the structure of my project, but when I try to change some elements appears the following screenshot: Can't convert Instance's Host to Work Plane. Try resetting Host to a Level., then a fatal error occurs , so, for me is quite upsetting that since I'm not able to continue with my project , anybody knows what's the problem?, any suggestion will be very appreciated, tnx in advance.
    Forum Addict jmk's Avatar
    December 31, 2012
    NM, USA
    1,504
    10:31 PM
    What structural elements are you trying to place? Is it always the same element in the same place, or does it occur when you try to place that element in other places? Have you checked your active work plane before placing the element?
    June 21, 2012
    Tours, France
    1,062
    06:31 AM
    Hi Jmk, tnx for your reply, there are Structural Framing "purling", I have tow of them one is 203 x 67 mm and the second one is 254 x 67 mm, those aren't located in the same place, in fact I've create reference planes for each one, the active work plane for some bizarre reason are unable or deactivated, but if I try to use another structural family It works , I believe is some problem within this specific family because if I uses another one it works fine.
    December 31, 2012
    NM, USA
    1,504
    10:31 PM
    That does sound like it's family based. That isn't an OOTB family is it? Can you place one that it will let you place and then change the type? Does the same error occur if you try to place it in a new project?
    June 21, 2012
    Tours, France
    1,062
    06:31 AM
    Hi Jmk, Yes it's a family based Purling, I'm attaching it, the family has a random behavior, in some projects works fine but in other it is totally crazy, tnx for your help.
    Purling_Cerramiento.rfa
    Alex Cunningham's Avatar
    Northern California
    3,575
    09:31 PM
    Andres is is not advised to place framing members attached to reference planes.
    June 21, 2012
    Tours, France
    1,062
    06:31 AM
    Hi all, tnx for your valuable help.
    July 4, 2013
    179
    10:31 PM
    Edit the family, uncheck 'work plane based'.
    "OMG I killed Revit"
    dzatto's Avatar
    5,236
    11:31 PM
    I know my buildings are small, but I do all my roof members on RP's so I can get them at the correct slope quickly and easily. I've never had any issues.
    I'm just curious as to what issues you're seeing using RP's.
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,543
    09:31 PM
    You're asking Alex about a post he made in May? He doesn't remember what he had for breakfast this morning let alone what he was doing in May
  1. Error
    By assem in forum Rendering and Gallery
    Last Post: November 3rd, 2013, 07:45 PM
  2. Revit Error
    Last Post: March 1st, 2013, 04:43 PM
  3. AutoCAD Error
    By gdoherty0102 in forum Coordination Tools
    Last Post: July 21st, 2012, 03:05 AM
    Last Post: November 26th, 2011, 02:16 PM
  5. Certificate error
    By ikinks in forum Forum Suggestions and Feedback
    Last Post: September 15th, 2011, 06:56 AM
