Thread: Default visibility/graphics settings Revit 2013
    May 4, 2012
    32
    01:05 AM
    What is it that controls visibility/graphics when a new view is made? When I create a new section, most of the worksets are set to "hide", most of the filters are set to "invisible", sections are set to "invisible" etc. I would like to change most of these so that the default setting is different. Anyone who can help?
    Thanks.
    10,618
    05:05 PM
    You can make a View Template the "default" that is used when a new view is created. In 2013 if you have View Templates linked to View Types, ity uses those. If they arent linked, it will use whichever one is set to Default. Its annoying to find the Default one, but if you go to the project browser and right click on a Wall Section, and hit Apply View Template, and select one, youll see an option for "Make this the default when new sections are made." The button is at the bottom left. Now when a new section of that Type is created, it will have those settings.
    May 4, 2012
    32
    01:05 AM
    Thanks. Im not entirely sure what you mean by "View Templates linked to View types", but as this project is an upgrade from Revit 2012, I guess that they arent linked.
    Anyway, when I right click on a section (I presume thats what you mean by a Wall Section?) in the project browser, I can "Apply Template Properties", but not "Apply View Template". In the "Apply Template Properties" dialogue box, I can't find a "Make this the default...." button anywhere. Any further suggestions?
    Member Barrie's Avatar
    August 3, 2011
    Kent, UK
    217
    12:05 AM
    If you go into the type properties for a view you will find the options you are looking for under identity data. View Type Properties - WikiHelp
    10,618
    05:05 PM
    Oh that's true! In 2013 they moved it there as well.
  1. Topography Surface: Visibility Graphics + Section Cut question (Revit 2011)
    By itchiamg in forum Architecture and General Revit Questions
    Last Post: August 29th, 2017, 01:19 PM
  2. Revit 2012 Visibility and Graphics & Linked Cad
    By rjb1972 in forum Architecture and General Revit Questions
    Last Post: February 2nd, 2015, 06:19 PM
    Last Post: October 26th, 2012, 02:16 AM
  4. Visibility/Graphics - Workset Visibility Setting
    Last Post: July 27th, 2012, 03:49 PM
  5. 3D visibility settings
    By Will P. in forum Architecture and General Revit Questions
    Last Post: June 22nd, 2011, 06:38 PM
