Thread: Elevation Tag kicking my a$$
    Member Ant123's Avatar
    January 30, 2013
    Dark & Bloody Ground
    58
    09:40 AM
    why do these two look different when they have the same properties?
    I want it to look like ElevA (normal)
    4,423
    01:40 PM
    Have you tried removing the view name label from the family?
    January 30, 2013
    58
    09:40 AM
    I thought to try that but not sure which family to open. would it be Elevation tag or Callout Tag?
    January 30, 2013
    58
    09:40 AM
    I tried to edit the family Elevation Mark Circle_Body to make the ref to the view name invisible but I got this error msg.Click image for larger version.
ID:	12733Click image for larger version.
    January 30, 2013
    58
    09:40 AM
    doh! I just needed to select Edit Type, then Elevation Tag (1/2" Circle) then the option w/o the view name.
    these things I do at the beginning of a project and forget how to do them by the time I start another.
    6,246
    08:40 AM
    Quote Originally Posted by Ant123 View Post
    set them in your template
    Senior Member JBZ's Avatar
    December 17, 2010
    Los Angeles
    677
    06:40 AM
    I don't recall the edits I made, so here are the 2 families needed...There are Types embedded for both BLDG and INT. Elevations (Filled & Unfilled)... The only issue are the lines in the Interior (unfilled) ones...but if I can get over it, perhaps others can ;-)
    You can download from here:
    "Circle" 1) https://www.box.com/s/ehf4qslk8e1lvy2yn6a1
    "Pointer" 2) https://www.box.com/s/z5gb2prv9icaubydx2rl
Name:	6-3-2013 12-20-59 PM.png
  1. elevation marker related to specific elevation view
    By Ning Zhou in forum Third party Add-Ins, API and R&D
    Last Post: February 20th, 2013, 07:24 AM
  2. Circular Toilet Room Elevation - Any Advice for "Unfolded" Elevation?
    By revit_user in forum Architecture and General Revit Questions
    Last Post: January 16th, 2013, 11:39 PM
  3. Elevation Tags - Reference view & Elevation in one tag?
    Last Post: January 10th, 2012, 09:17 PM
  4. Elevation Marker in elevation view?
    By RaiderArch in forum Architecture and General Revit Questions
    Last Post: December 2nd, 2011, 07:48 PM
  5. Site elevation vs. Shared Elevation
    By KimArndt in forum Architecture and General Revit Questions
    Last Post: March 28th, 2011, 02:24 PM
