Results 1 to 10 of 12
Thread: Analytical Model Edge Warning
    "OMG I killed Revit"
    dzatto's Avatar
    5,280
    07:33 PM
    I've never seen this before. I have 3 pieces of specialty equipment that cut my slab. I've used these families for years, but I'm getting errors in 2014. See attached image. I can't delete the family, move the family, delete it from the PB. Nothing. How do I get past this?
    dzatto's Avatar
    5,280
    07:33 PM
    I figured out where to turn it off in the slabs properties. It works fine if it's off, but why is it doing that in the first place? Anyone know?
    I modeled a new slab in the same project, and created a new instance of the families. It worked fine even with analytical model enabled.
    Autodesk TheViking's Avatar
    Lexington, MA
    157
    08:33 PM
    Any images of the floor? Did the openings remove the whole edge of the floor?
    July 3, 2013
    12:33 AM
    Did you have any luck with this error because I am experiencing the same error when trying to move, delete or revise a wall and its causing me all sorts of headaches and I haven't been able to find any solutions.
    3,199
    05:33 PM
    You know you shouldn't cut into pre-stressed concrete?
    I assume you are using Revit vs Revit Architecture? "One Box" has all the stuff including trade specific warnings. Sounds like your family might be at the very edge of a slab, leaving a tiny sliver? You can eliminate them if you tell Revit in its properties that it isn't used for analysis.
    July 3, 2013
    12:33 AM
    Yes, I am using Revit. I have tried to edit the "enable analytical model" to turn it off in both the slabs and walls but it always returns the same error. I am relatively new to revit and am still finding my way around.
    dzatto's Avatar
    5,280
    07:33 PM
    Okay, we need to revisit this thread. Like Bails, I'm now having a similar issue with a wall. I can't move it, delete it, stretch it, change it's structural parameter. Nothing. It gives me the attached "unexpected error" (never seen this one before). Enable analytical model is unchecked. I need a fix, QUICK!.
Name:	unexpected error.PNG
    dzatto's Avatar
    5,280
    07:33 PM
    Okay, I just got it to work. The wall was a stacked wall, and I have a separate block wall behind it. The two walls were joined. I noticed that I would get the same error if I tried to delete the block wall, as well as a perpendicular wall that this wall ties into with a T intersection. The corner intersection on the other side worked fine ( I could delete that perpendicular wall with no issues).
    So, I unjoined the two walls, and that fixed all of the walls in that area that were giving me the error. I rejoined them, and they are still working properly. Is there a join bug we don't know about?
    October 29, 2013
    07:33 PM
    I have the same issue and I am trying to avoid modeling a new slab as I will loose all my dimensions. How did you get past the error?
    dzatto's Avatar
    5,280
    07:33 PM
    Turning off the "enable analytical modeling" in the slabs properties worked for me.
  1. How to add Analytical Model to Adaptive Family?
    By Davide in forum Structure - Family Creation
    Last Post: February 11th, 2013, 08:18 PM
  2. rebuild analytical model?
    Last Post: October 12th, 2012, 05:17 PM
  3. Analytical model
    By jbenoit44 in forum Structure - General Questions
    Last Post: June 21st, 2012, 03:34 PM
  4. Analytical model for slabs
    By lucis29 in forum Structure - General Questions
    Last Post: January 7th, 2012, 01:36 PM
  5. Analytical Model Lines
    Last Post: December 16th, 2011, 10:18 PM
