Results 1 to 10 of 12
Thread: Stairs profile
    3,231
    11:57 AM
    Stairs profile
    How would you create stairs with this section (the cyan profile in the attached image)?
Name:	stair section.JPG
    3,231
    11:57 AM
    So far the closest I can get using the stairs type properties dialog is this: (see attached). Perhaps I am going to have to show the actual section in a 2D detail or in a section view with a Edit Cut Profile operation? I know it could be modeled in 3D but its one of those things where one has to decide between time invested vs. benefits.
    Kingdom of Denmark
    4,278
    05:57 PM
    Alf, you "could" choose not to use the regular Treads at all, and instead model the Treads as custom Balusters (Railing with 1 baluster pr. tread)
    Just like Phil Read did at AU2009 (AB114-1 Insanely Great Stairs and Railings with Autodesk Revit)
    PS. Believe that Eric Wing did a similar class in 2009....
    Alex Cunningham's Avatar
    Northern California
    3,576
    08:57 AM
    Quote Originally Posted by alfredo medina View Post
    time invested vs. Benefits.
    my time is worthless
    Member Ben-May's Avatar
    Melbourne,Oz
    305
    02:57 AM
    Nosing Profile
    You can easily do that sort of tread as a nosing, Just create the nosing profile based on the tread dimensions. The Apply to a stair with a tread thickness less than the minimum depth of the nosing profile and the same width
    Try the attached file for a quick workup of the image you attached
    Hope that helps!
    Moderator mark b's Avatar
    NSW Australia
    1,436
    01:57 AM
    Quote Originally Posted by Ben-May View Post
    Hope that helps!
    Hey Ben, awsome tip. Talk about thinking "outside the square", tried a couple of different profiles, awsome !!
    03:57 PM
    This actually came up in the Mastering Revit 2011 series. I believe they gave two kinds of possibilities:
    1. Create as a baluster or
    2. Create a a nosing profile as shown above.
    I think for this particular instance I have to agree with Ben-May: Use Nosing Profile.
    BTW: Purchase the book Mastering Revit 2011!! The stairs section is AWESOME!!! (worth buying the whole book if you ask me)
    3,231
    11:57 AM
    Hope that helps!
    Nice, but if you look at the original post showing the profile, that is the front section of the whole stair, not the side view of one of the treads. In your example, the nosing profile has been applied as the section of the thread. Maybe the nosing profile does not work, then. Maybe the custom baluster is the only solution?
    Junior Member Matt Stachoni's Avatar
    December 11, 2010
    Newark, DE
    11
    11:57 AM
    Alfredo,
    What units are we in? Are the dimensions Centimeters?
    Melbourne,Oz
    305
    02:57 AM
    I didnt realize the detail was a front view of the stair.You can still create the steps with the nosing profile by applying to the "Front & Left" you can create the stringer with the stair as well, it will look fine in 3D but will need cleaning up in section. Wasn't sure on the units either, guessing they are centimeters
  1. Yea again STAIRS
    By mb90 in forum Architecture and General Revit Questions
    Last Post: May 9th, 2011, 04:48 PM
  2. Wrap Stairs Around Exteior Corner
    Last Post: May 1st, 2011, 11:52 PM
  3. Stairs and Levels
    Last Post: April 4th, 2011, 03:12 PM
  4. Stairs beyond cut in Phases
    Last Post: February 16th, 2011, 06:44 AM
  5. Monolithic stairs at the radius
    By Severnik in forum Architecture and General Revit Questions
    Last Post: December 28th, 2010, 06:21 AM
