Results 1 to 10 of 12
Thread: Generic model floor based line weights
    December 31, 2010
    Singapore
    195
    03:44 AM
    I have created a floor based generic model. I would like to be able to control the line weights of this model once it's joined to a floor in the model. At present it is assuming the line weight thickness of the floor its joined to. Within the GM I have tried putting nest families such as a site family so I can control the line weight separately. This is all good but once I join the the floor all the line weights go out the window.
    This attached image shows the GM family joined and unjoined.
    What am I missing?
    2,677
    05:44 AM
    When you join geometry (geometries? geometrii?) they 'become one'. Not sure if what you are wanting is possible with the 3D joined geometry, unless you start fooling around with visibility settings and nested annotation trickery. Or keep it unjoined and use invisible linework to hide the intersections
    March 21, 2011
    Brisbane
    290
    05:44 AM
    You can try:
    1. In the family editor create a new subcategory for your model items. Creating Family Subcategories - WikiHelp When the family is loaded in the project you can change the line style of the new subcategory to suit.
    2. Create filters and use them on your views (or in view templates)
    Cheers,
    Jh
    December 31, 2010
    Singapore
    195
    03:44 AM
    Thanks for replyjh75. Yes I created subcat for different components of family. Unfortunately when I join to floor all these setting are 'taken over' by the floor line weights, even if I apply view filter. The line weight control is about graphic hierarchy, I don't wont the interior of the drain (screed) or drain cover (mildsteel) to have the same importance thickness as the RC slab. The office I work in is quick particular abt this and I tend to agree.
    2,677
    05:44 AM
    Quote Originally Posted by redmonki View Post
    I dont get why you're trying to join the geometry of a metal cover with a concrete floor. They're different elements made of different stuff. Is that why you've used generic model category?
    December 31, 2010
    Singapore
    195
    03:44 AM
    The GM is meant to be a composite family ie linear drain RC, interior screed lining of drain & drain cover. The family is working fine in that when I join with floor it seamlessly integrates and shows a clean section without having to clean up anything. The last piece of the puzzle is getting control over the line weights. Yes I can use a nested detail group in section view but its fiddly and less clean.
    It would be nice if subcat line weights could retained their own properties once joined.
    2,677
    05:44 AM
    Joined geometry is joined geometry. Tried shared nested components? last resort might be linework.
    December 31, 2010
    Singapore
    195
    03:44 AM
    Yeah have tried. Failed. Maybe I'm asking too much, but to me it seems logical that you can join geometry but retain line weights.
    2,677
    05:44 AM
    Seems logical to me that the join geometry tool was designed for pulling pieces together to create a unique part that couldnt be created as a single piece of geometry (in itself a hack), so I still dont see how a metal cover and a concrete floor could be considered a single element. Add a screed layer you still have 3 separate components made of 3 different materials.
    December 31, 2010
    Singapore
    195
    03:44 AM
    So are you suggesting I model each of those components separately and then align them together in the model?
  1. Generic Model Floor Based Floor
    Last Post: June 6th, 2014, 05:19 PM
  2. Model line Weights
    By cve60069 in forum Architecture and General Revit Questions
    Last Post: January 23rd, 2013, 04:09 PM
  3. Make Generic Model Adaptive > Floor Based
    By qutaibah in forum Architecture - Family Creation
    Last Post: November 1st, 2011, 08:20 AM
  4. Floor Pattern Line Weights
    By MPwuzhere in forum Architecture and General Revit Questions
    Last Post: October 10th, 2011, 11:12 AM
  5. Line Based Generic Family-End Points Problem
    Last Post: January 7th, 2011, 10:02 PM
