Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Trick to get environmental reflections
  1. #11
    December 20, 2010
    singapore
    91
    08:31 AM
    wow awesome! thanks!
  2. #12
    Senior Member Tim West's Avatar
    December 9, 2010
    Auckland, New Zealand
    618
    09:31 PM
    I developed this idea during the days of accurender, as I didn't realise there was an option for a spherical environment map. I used to use a transparent wall with a decal attached.
    I have found this a little more problematic since 2010 as transparent walls cast shadows. so be wary of where you place your wall.
    This would also work well for a backdrop as you could achieve perspective based on the angle of the image to the camera.
  3. #13
    Gold Coast
    2,765
    06:31 PM
    Quote Originally Posted by Tim West View Post
    I'd call that a bug then, something 100% transparent shouldn't cast ANY shadows!
    I've always done what Munkholm suggests and NOT use something you'll be scheduling (like walls), i usually make a small extrusion of a never-used category, grouped with the decal so if i delete the decal the extrusion goes too.
    You can also create your own rpc's this way using .png's
  4. #14
    August 1, 2012
    Philippines
    08:31 AM
    Awesome! I should try that!
  5. #15
    Member Minotaur's Avatar
    July 26, 2015
    126
    09:31 AM
    In max there is enviromental map, is there something simillar in Revit, I realy cant find it?
  6. #16
    Member truevis's Avatar
    January 7, 2011
    112
    04:31 AM
    Quote Originally Posted by Minotaur View Post
    In max there is environmental map, is there something similar in Revit, I really can't find it?
    Only in the cloud renderer; there are some presets for environmental maps. I don't think one can upload one's own.
  7. #17
    July 26, 2015
    126
    09:31 AM
    I dont upload anything on clouds... stealing ideas... too bad they dont have that option now I need to send it to max...
  8. #18
    January 7, 2011
    112
    04:31 AM
    Quote Originally Posted by Scott D Davis View Post
    I've added credit for this tip back to this post by Truevis on the WikiHelp.
    "Autodesk Wikihelp has been retired" -- at least one might find the tip back here with a web search. Click image for larger version.
Name:	2017-04-12 00_11_11.png
  1. Another Shortcut Trick
    By mark b in forum Tutorials, Tips & Tricks
    Last Post: January 12th, 2016, 01:27 PM
