Results 1 to 10 of 18
Thread: Trick to get environmental reflections
    Member truevis's Avatar
    January 7, 2011
    112
    11:26 AM
    Remember in pre-Revit 2009 with AccuRender, we could put in spherical backgrounds and glass would reflect the background?
    I found a trick to get context-appropriate reflections on glass with mental ray rendering.
    Get your image that you want to reflect. (Maybe a Google Maps street view screen capture.) Put that image on a Decal and slap it upon a wall that is opposite of your glass. The Decal will reflect into your rendering.
    Member Mike Ferrell's Avatar
    London, Ontario, Canada
    60
    10:26 AM
    That is one cool tip! Thanks for that.
    Moderator mark b's Avatar
    NSW Australia
    1,432
    02:26 AM
    Sweeeeeeeeeeeet .........
    March 5, 2011
    Southern California
    666
    07:26 AM
    03:26 PM
    ok, does this work for Domes too? I have some of these Dome shaped environment pictures for rendering. I created a Dome using the massing tool, applied a wall, but I can't seem to be able to place a Decal on this.
    Kingdom of Denmark
    4,262
    04:26 PM
    Ive used it with domes in the past... but not with a decal - used a custom material with the "dome" environment added to the actual dome.
    December 17, 2010
    Pembroke Pines, FL
    571
    11:26 AM
    If you use a wall with a material with full transparency and a decal with a cutout applied you can have a background rig setup so that you hide the horizon line with a row of trees for example and your dome could have a real sky texture applied to it.
    Kingdom of Denmark
    4,262
    04:26 PM
    Just tried to recreate the Dome trick, but cant for the life of me get the custom material to behave on the dome shape
    And BTW, be careful with placing the Decal on a wall - At least if you are doing quantity takeoffs too Instead you could create an in-place extrusion in a category that you do not use for anything else. e.g. "Nurse Call Devises" or something like that, which are rarely scheduled in architectural projects.
    03:26 PM
    I usually do my rendering in an added Phase. In this Phase I also place the RPC's and other rendering stuff so it doesn't get in the way during the modelling work and on my Sheets.
    March 5, 2011
    Southern California
    666
    07:26 AM
    Quote Originally Posted by Scott D Davis View Post
    I've added credit for this tip back to this post by Truevis on the WikiHelp.
  1. Another Shortcut Trick
    By mark b in forum Tutorials, Tips & Tricks
    Last Post: January 12th, 2016, 02:27 PM
