Results 1 to 10 of 10
Thread: Creating floor slab
    Member bangobeat's Avatar
    April 14, 2011
    263
    05:24 AM
    Creating floor slab
    What is the best way to create this type of floor slab?
    Kingdom of Denmark
    4,262
    04:24 AM
    You could create the bottom parts as "Slab Edges" or create the floor as an "In-place" by extrusion. (Id go for the first option...)
    03:24 AM
    Are these thickened parts present over the complete length of the floor slab? If so, I would create the big and small part as a Generic Profile and make Slab Edges of them using a horizontal offset from the side of the floor slab. When made of the same material the join should automatically clean up.
    April 14, 2011
    263
    05:24 AM
    When i make my own slab edge, after loading and placing it, its changing shape.. help?
    April 14, 2011
    263
    05:24 AM
    nevermind, already fixed it, the problem was that every edge has 3 different properties that can be loaded. Everythings is allright.
    "OMG I killed Revit"
    dzatto's Avatar
    5,236
    09:24 PM
    I never realized you could offset slabe "edges" to be anything other than an edge. Or did I read that wrong?
    Is that how you guys do interior beams? I created a beam family for my interior beams. Which is a better method?
    April 14, 2011
    263
    05:24 AM
    how to join two slab edges so it could be round connection?
    dzatto's Avatar
    5,236
    09:24 PM
    I don't know, but I love your attachments. I noticed the smiley, and now the "hell yeah".
    03:24 AM
    Yep, you can give them an offset to the side which they are placed on. Place the slab, select it and in the properties palette a horizontal and vertical offset can be filled in.
    btw: same goes for all sweeps (wall sweeps, fascias, gutters, etc)
    03:24 AM
    Quote Originally Posted by bangobeat View Post
    The only way you can do this is make the floor this shape. The Slab Edge follows the Floor Edge.
  1. Generic Model Floor Based Floor
    Last Post: June 6th, 2014, 05:19 PM
  2. Slab Edges!!!!
    Last Post: May 26th, 2011, 12:01 AM
  3. Waffle Slab
    By iitdesigner in forum Architecture and General Revit Questions
    Last Post: April 18th, 2011, 03:13 PM
  4. Creating Views
    By cwwalder in forum MEP - General
    Last Post: February 9th, 2011, 06:51 PM
  5. Creating views
    Last Post: January 18th, 2011, 04:24 PM
