Thread: Greying out Yes/No visibility parameter for specific family types
    May 9, 2013
    55
    10:12 PM
    Is there any way by which I can grey out or disable the visibility parameter tickboxes for specific family types and enable it to either turn on/off in the other types? I have tried many of those formulae but those enable me only to permanently turn on/off the parameter for different types. I just want to disable some tickboxes completely for specific family types so that the user is not able to enable a wrong part even by mistake.
    Any help is appreciated.
    Thanks in advance
    Moderator mark b's Avatar
    NSW Australia
    1,432
    03:42 AM
    Use at your own risk
    Edit...
    Sorry just re read your post, this solution is just "off" altogether
    4,426
    04:42 PM
    You'll need to tie the Yes/No paramter to a conditional statement, which would be comprised of conditions existing in the type that limit/restrict/allow the yes/no parameter. Take a look at the "formulas for everyday use" thread and it'll all become clear.
    May 9, 2013
    55
    10:12 PM
    Ya actually I had tried giving such conditional statements but those allow me only either to turn the parameter on or off for each type. We are using these visibility parameters as instance parameters so that it works as check-box options in the project level. Using these conditional statements, the sole purpose of the visibility parameter check-boxes is destroyed as all these appeared greyed out, though either on/off. We need some parameters to be greyed out,i.e inaccessible, in specific family types and appear active as usual in the others. Hope that makes it clear.
    Forum Addict jmk's Avatar
    December 31, 2012
    NM, USA
    1,498
    09:42 AM
    Quote Originally Posted by sabari2504 View Post
    Revit can't do that unfortunately, at least not without some sort of API. What you can do is set up some sort of error indicator, which is only visible if a the user makes a choice that isn't appropriate for that type. What sort of family is it? What needs to be an instance parameter in some types, but not accessible in others?
    Member kowen1208's Avatar
    January 18, 2013
    Utah
    354
    10:42 AM
    Only thing I can think of is layering it with conditions between the box they check and the feature being enabled. For example:
    Yes/No Parameters:
    Feature Available = (value set by type)
    Enable Feature = (value set by instance)
    Idiot Check = and(Enable Feature, Feature Available)
    Visibility of feature would be driven by Idiot Check.
    Member anthonyB's Avatar
    August 31, 2011
    Sydney, Australia
    435
    03:42 AM
    It might be easier just to have two different families. Yes the downside, is that if you modify one you may well have to modify the other too. But it might be easier for your users to understand, and for you to remember the differences if they are two different families.
    March 14, 2018
    01:12 PM
    Permanently turn on/off the parameter for different types
    Thanks in advance
    Hi there I'm sorry for replying to an old thread, but could you please give a brief example of a formula you would use to "Permanently turn on/off a parameter for different types" like you mentioned above?
    Cheers,
    Last Post: October 14th, 2012, 04:18 AM
  2. Revit OpEd: Family Types Dialog - Lock Parameter
    Last Post: September 28th, 2012, 03:15 AM
  3. Visibility parameter and nested family: bug?
    By jbenoit44 in forum Structure - Family Creation
    Last Post: August 30th, 2011, 04:23 PM
  4. shared parameter types
    Last Post: June 17th, 2011, 10:11 PM
  5. insert specific tag in family
    By ikinks in forum Architecture - Family Creation
    Last Post: May 5th, 2011, 06:33 AM
