Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Approval & help needed
    08:45 AM
    Hi guys,
    First off: thanks to all that contributed with some great Addons...
    Now, here's the question:
    I've found three great apps with code floating around here:
    - Wall Join Allow/Disallow by API, created by Krispy5
    - Mirror parameters, created by Feio
    - Retrieve Filtered Elements by Nelson.
    Now, there's probably more to follow but would it be nice to put all of these under an RFO Addon? I know that starting 2012 you can create your own Ribbon Tabs (check out the Room/Window Area Addin), so this would be cool to create (and also a good excercise for us noobs).
    But, I don't want to do this without the author's concent. So anyone who posted a sample here on RFO, please respond...
    Oh, and also it would be nice if someone could give me some pointers on how to actually make that happen Cause I'm kind of in the dark on that one...
    Member KiwiCodes's Avatar
    351
    08:45 PM
    I Think that is a great idea.
    I would be prepaird to add some of our free apps to it as well as add some other small apps that I have floating around in the back of my head
    08:45 AM
    Cool, thanks!
    btw: already found the way to create a ribbon tab (read the manual).
    351
    08:45 PM
    LOL. That sometimes helps. I haven't had a chance to look at that yet as I have been flat out finishing off an API program for a client.
    BTW we implemented custom ribbon Tabs in Revit 2010 and 2011 using GuyR's way which worked a treat. I'm sure the 2012 way though will be a little more integrated
    Member krispy5's Avatar
    68
    07:45 PM
    No problem to include mine, I'll add my text align and a change text case one as well. Do you want images for the tool buttons?
    I too used guy's method to add a custom tab last year, i used the standard method this year.
    08:45 AM
    Quote Originally Posted by krispy5 View Post
    That would be great. I also PM'd Klaus for a bitmap from the Revitforum logo, so we can make this one big giant commercial
    That said, there's also the possibility to include a flyout explanation (like the tooltips you also find in native Revit commands in which I would like to give credit to the actual writer of the code. Does anyone have any experience with this?
    68
    07:45 PM
    I have done some extended tooltips on our custom ribbon tab, see screenshot:
    08:45 AM
    Right, exactly like that. Care to share how you did this?
    68
    07:45 PM
    You just assign a "ToolTip" and "LongDescription" to the "ButtonData" object.
    68
    07:45 PM
    Hi Martijn, how are you going with this? Do you need any help? I had a few thoughts about how to achieve this.
  1. Help Needed: Data Extraction From Revit
    By akarthick in forum Third party Add-Ins, API and R&D
    Last Post: November 19th, 2018, 09:28 PM
  2. Help needed making a 3D Arched Building
    By Steven82 in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: May 14th, 2011, 05:51 PM
  3. Help needed making a 3D Arched Building
    By Steven82 in forum Architecture and General Revit Questions
    Last Post: May 14th, 2011, 04:50 PM
  4. DD Architect needed for Shanghai firm
    By Dennis_n in forum Career Corner
    Last Post: April 22nd, 2011, 08:54 AM
  5. Bump: help needed
    By jbenoit44 in forum Rendering and Gallery
    Last Post: March 16th, 2011, 09:29 PM
