Thread: Tagging Bottom of Finish Floor from Revit Link (Spot Elevations)
    December 20, 2010
    singapore
    91
    07:37 AM
    For my current project, I need to add spot elevations to denote the finish floor level, as well as the structural slab level. Typically, I will have the floor finish and the structural slab as two separate elements - from there, I can use a spot elevation that indicates both the top and bottom of the finish floor to get both the finish and structural floor levels (the bottom of the finish floor is the same as the top of the structural floor).
    In my current predicament, these two floors are in a separate file which is linked into my file with annotations. When I try to use the spot elevation tool on the linked file, it takes the top of the finish floor and the bottom of the structural floor which is a separate element. Example: 50mm finish (+100.50) on a 300mm structural slab (+100.00). The value it will give me is +100.50 for the finish, the but the bottom will be +99.70 instead of +100.00 as it is recognizing the two elements as one.
    Does anyone have any workarounds to this?
    Thanks!
    February 3, 2011
    402
    03:37 AM
    Darryl,
    As a test, if you temporarily turned off the structural slab and then added the spot elevation will it take just the finish floor?
    July 1, 2011
    Bengaluru, Karnataka, India
    29
    01:07 PM
    Hi Darryl,
    keep all the structural elements in one file. For example, if you have your structural slab in one file then make sure your finish floor is also on the same along with retaining walls, foundations and column elements. Try doing this . You should be able to get the spot elevation - both top & bottom elevation right.
    August 6, 2015
    02:37 PM
    Yes, as Jj Mac said, just tap to chose the below slab then hide it, the spot elevation will automatically show the bottom of the above slab.
    2,796
    05:37 PM
    What hat happens if you temp hide (tab select) the FF in the linked model, can you then SE the top of the slab?
    I'm guessing the floors aren't joined right?
    Quote Originally Posted by manhrunghoang View Post
    I'm pretty sure that hiding a floor will also hide the SE of that floor.
    September 19, 2016
    09:37 AM
    Still having this issue in Revit 2019. Had to hide element in view the structural slab below, in order for spot elevation to show correct bottom of finish floor. Ridiculous.
  1. Spot Elevations
    By ChrisEmsley in forum Structure - General Questions
    Last Post: July 8th, 2019, 11:25 AM
  2. Revit Spot Elevations, Rooms and Color Schemes Problem
    By dp stuff in forum Architecture and General Revit Questions
    Last Post: June 24th, 2013, 05:46 PM
    Last Post: February 21st, 2012, 02:45 PM
  4. Spot Elevations in Section?
    By GenreNomad in forum Architecture and General Revit Questions
    Last Post: December 23rd, 2011, 12:25 AM
  5. Exterior Finish Tagging
    Last Post: July 14th, 2011, 04:03 PM
