Results 1 to 10 of 15
Thread: Parametric Finish Materials
    Kingdom of Denmark
    4,279
    10:03 AM
    Lightbulb Parametric Finish Materials
    Inspired by this thread, I┤ve created the following short video to explain how to apply parametric finish materials to Revit Families.
    Note, this may not work in RST and MEP, and it does NOT work in Revit 2012 either (A fix for 2012 should be on its way)
    This is great for applying different finishes to the same object. e.g. a window frame made of "Wood" but with "Paint 1" on the interior side and "Paint 2" on the exterior side. (In this case you┤d need two "Finish Materials")
    Basic steps:
    1. Create a "Material" Parameter (If it doesn┤t already exist)
    2. Create a "Finish Material" Parameter
    3. Apply the "Material" parameter to the actual geometry
    4. Use the paint tool to apply the "Finish Material" (Param) to the desired faces of the geometry
    December 20, 2010
    singapore
    91
    08:03 AM
    Wow! Awesome tip - thank you for that. Never even knew painted surfaces could be set to a parameter.
    Spanish Moderator JCM's Avatar
    December 17, 2010
    Pembroke Pines, FL
    571
    04:03 AM
    Awesome Tip! I now understand all the talk about this
    3,231
    04:03 AM
    Is there a solution for this issue, not working in RAC2012? Can't we paint surfaces with material parameters anymore? What is the workaround, then?
    Kingdom of Denmark
    4,279
    10:03 AM
    Quote Originally Posted by Alfredo Medina View Post
    No workaround Alf... It┤s simply broken in 2012. Aaron mentioned that the Factory is working on a fix, so I┤m assuming (or rather hoping) that there will be a Hotfix available soon, or maybe a early WU1 to take care of it.
    "OMG I killed Revit"
    dzatto's Avatar
    December 9, 2010
    5,275
    03:03 AM
    OOOhhhhh, that's what you and Aaron were talking about. It made no sense to me at all in the other thread.
    Thanks for the tutorial. Bookmarked. I'd rep you, but you have enough already.
    Forum Addict Andres Franco's Avatar
    June 21, 2012
    Tours, France
    1,122
    10:03 AM
    Awesome tip, tnx for posting the video, it is very clear and useful .
    November 13, 2013
    Ha Noi, Vietnamese
    08:03 AM
    Thanks you very much.i am learning revit special material. Thanks you
    April 22, 2012
    Santiago, Chile
    66
    05:03 AM
    I have a big question about this.
    Taking the example on the video, would it be possible to tag both materials?
    I'm searching for a solution for what is a big issue at work. We model a lot of furniture families which, in reality, consist in two elements (for example, a table made of MDF with plastic laminate on it). I'm doing the same on the video, but I can't identify both materials in 2D views.
    June 21, 2012
    Tours, France
    1,122
    10:03 AM
    Hi Jaime, for that you are trying to do you must have 2 different models ie: one model to the desk and one more to the finish, If you'll have a laminate wooden desk and you want to schedule or tag both materials, you must have 2 different surfaces for be able to do that. regards.
  1. Challenge: a parametric scissors lift with multiple arms.
    By Alfredo Medina in forum Architecture - Family Creation
    Last Post: December 3rd, 2019, 04:34 AM
  2. Challenge: A parametric corner piece
    Last Post: July 5th, 2013, 04:59 PM
  3. 2012 - Parametric Paint option broken ?
    By Munkholm in forum Architecture and General Revit Questions
    Last Post: July 12th, 2012, 02:40 PM
  4. More Parametric Freakyness
    By mdradvies in forum Architecture - Family Creation
    Last Post: February 14th, 2011, 05:28 PM
  5. Phased Materials
    By mark b in forum Architecture and General Revit Questions
    Last Post: December 17th, 2010, 12:19 PM
