Results 1 to 10 of 10
Thread: AsiaSW - PowerSheets for Autodesk Revit
    August 22, 2012
    18
    03:49 PM
    Simple and useful
    Do you need to duplicate in a fast way existing sheets in your project ?
    Create new sheets maintaining current view position?
    Easy duplicate more views?
    PowerSheets is the right solution
    PowerSheets for Autodesk« Revit« provides a tool for management sheets, duplicate and creates new sheets by selected base sheet(template) and adds new views according to the selected view position in your template.
    More information on Autodesk Revit Exchange Apps Store Autodesk Exchange Apps
    View this video demo https://chronicle.autodesk.com/Main/...3-df461ab67a02
    August 22, 2012
    18
    03:49 PM
    Smile PowerSheets for Autodesk Revit 2014 New Release
    Released new release for PowerSheets for Autodesk Revit 2014 2014.0.7.41968, we have corrects some bugs an added this 2 features:
    • Order View Name/Number or View Number/Name
    • Support for Assemblies Sheets/Views
    For more information:
    PowerSheets | Autodesk Revit | Autodesk Exchange Apps
    Free of charge if you have 2014 PowerSheets release.
    Enjoy!!
    Member colliert's Avatar
    May 2, 2012
    Little Rock, Arkansas
    74
    08:49 AM
    I can't find any comments or reviews on this app for Revit...does anyone here use this, and have any thoughts on it?
    We have a project where recreating floor plan sheets for different phases would make this very useful...
    August 22, 2012
    18
    03:49 PM
    Lightbulb
    Hi, if you need to try it, simply send me an email with your contact
    Regards
    AsiaSW
    August 22, 2012
    18
    03:49 PM
    Exclamation
    Released new version PowerSheets for Autodesk Revit 2015 2015.0.2.26371, added this 2 features:
    • Added new Option, if checked try to create duplicate views as Dependent if supported, if unchecked duplicate with detailing.
    • Support for Autodesk« Revit 2015
    August 1, 2014
    01:49 PM
    I do residential design work for volume home builders. Each plan has at least 2, sometimes 3 or 4, different facade options, keeping the same basic floor plan. Each facade option has it's own complete set of sheets, which could be anywhere from 10 to 20 sheets. I was hoping this program would allow me to duplicate all the sheets at once, but I can only do 1 at a time. Not as big a time saver as I was hoping it would be. Are there any plans to update the program to allow me to pick multiple sheets to duplicate at the same time?
    August 22, 2012
    18
    03:49 PM
    Hi Tom,
    thanks for reporting, I will hope to enter your requests in future updates.
    Regards
    AsiaSW
    August 22, 2012
    18
    03:49 PM
    Lightbulb
    Released new version PowerSheets for Autodesk Revit 2014/2015 2015.0.4.28402, added this new features in 2014 and 2015 release:
    • New Option, If checked copy schedule otherwise use same schedule in sheets copied
    • Copy also empty sheets
    • Improved performance in large project
    Free of charge if you have 2014 or 2015 PowerSheets release.
    Enjoy!!
    August 22, 2012
    18
    03:49 PM
    Released new version PowerSheets for Autodesk Revit 2016 2016.0.4.30621, added compatibility with Autodesk Revit 2016.
    August 22, 2012
    18
    03:49 PM
    Released new version PowerSheets for Autodesk Revit 2017 2017.0.4.21854, added compatibility with Autodesk Revit 2017.
  1. AsiaSW - PowerMeasure for Revit
    By asiasw in forum Commercial & Free Add-Ins/Extensions
    Last Post: April 19th, 2016, 07:51 PM
    Last Post: June 24th, 2013, 11:15 AM
    Last Post: September 18th, 2012, 11:15 AM
    Last Post: April 1st, 2012, 02:45 AM
    Last Post: August 5th, 2011, 11:11 AM
