Results 1 to 10 of 12
Thread: Help Needed: Data Extraction From Revit
    May 11, 2011
    5
    02:19 AM
    Question Help Needed: Data Extraction From Revit
    Hello All,
    I am very new to Revit and it's API functionalities. I am working on a project for which i need to extract the site boundaries, and building layout information from a Revit model. i.e. the x,y,z coordinates of the site boundary and the the building location. I am planning to use this information in developing a site layout planning model. As i am new to Revit and haven't used any of the functionalities, I have now clue on how to extract the required x,y,z coordinate information from a Revit model. I tried google, but not luck :-(.. Could anyone please help me with this? I would really appreciate any help with this, and i am in an urgent too... Thanks!!
    March 30, 2011
    Aarau, Switzerland
    105
    04:19 AM
    You need the SDK. Its included in your Revit distribution. There is a RevitAOI.hlp that is impotant but doesnt explain much. The examples that arew included in the SDK are a very good source of informition. And in version 2012 there is a great "Revit 2012 API Developer Guide.pdf". I like this dokument altough it is not complete yet. And very important - you need the building coder blog written by Jeremy Tammik(http://thebuildingcoder.typepad.com). If you combine this sources you have everything you need for a depp understanding of the API
    02:19 AM
    You could also use Excitech Toolkit. This is a free Addon. You'll need to create a point based family (Simple Generic Model Family will do). Draw a crosshair on the insertion point, place where needed, create a schedule of the Generic Model family and use the Excitech Toolkit to create and fill x, y and z-paramters. The schedule can be exported to a txt-file which can be imported in Excel.
    May 11, 2011
    5
    02:19 AM
    Thanks a lot for the information. I would go through the provided sources and see if it helps me. I tried the ODBC export option in Revit, but was not able to get the coordinates from the exported database. Do you have any thoughts on if the Revit RDBLink would help me getting the coordinates information?
    Thanks & Regards,
    Karthick A.
    May 11, 2011
    5
    02:19 AM
    Thanks a lot for the information. I have downloaded the toolkit and installed. As i am very new to Revit, I have no clue on how to create the point based family (Simple Generic Model Family will do), and draw a crosshair on the insertion point. I will try to go through the toolkit manual and see if i can figure it out. Will let you know where i stand and if i need your further assistance to get through it :-)
    Thanks and Regards,
    Karthick A.
    02:19 AM
    How to create a point-based family:
    In Revit, click the R > New > Family > Generic Model
    This IS a (Insertion) Point Based Family. The crosshair you see in reference planes is the insertion point of the family.
    Simply draw two lines of any given length and lock to the refplanes.
    Import the family into Revit. Use Excitech Toolkit to create parameters for the family (they have a good tutorial on this).
    Good luck!
    May 11, 2011
    5
    02:19 AM
    Thanks for the info. I am going through the exercise right now. Will let you know if I was not able to get through. Thanks again!!
    Good luck!
    Member truevis's Avatar
    January 7, 2011
    112
    10:19 PM
    Even without using the API, you have property lines that can be tagged & scheduled, and spot coordinates (which can also show elevation) that can be placed in a view. Specify Coordinates at a Point to set your 0,0.
ID:	2146   Click image for larger version.
    May 11, 2011
    5
    02:19 AM
    I was not able to follow it. If you don't mind, could you please explain in further details about how i need to do so? Thanks!!
    Quote Originally Posted by truevis View Post
    Junior Member Drafter1981's Avatar
    July 14, 2014
    New Jersey
    5
    10:19 PM
    Any update on how to do this (How do you EXTRACT DATA)
  1. Measuring / Coordinate Extraction
    By Inspyra in forum Architecture and General Revit Questions
    Last Post: May 25th, 2011, 10:48 PM
  2. Approval & help needed
    By mdradvies in forum Third party Add-Ins, API and R&D
    Last Post: May 11th, 2011, 10:19 AM
  3. Bump: help needed
    By jbenoit44 in forum Rendering and Gallery
    Last Post: March 16th, 2011, 09:29 PM
  4. Viewport Identity Data
    By Alex Cunningham in forum Third party Add-Ins, API and R&D
    Last Post: December 13th, 2010, 03:40 PM
