Thread: Precast Floor problems when trimming shape of precast
    Member ryntau's Avatar
    October 11, 2012
    St. Louis
    405
    12:11 AM
    I'm working on my first precast floor project using Revit, and am coming across one issue that I can't resolve. When I trim the floor panel, to get around a stair core, any panels that abut them at 90 degrees stop at the original edge, instead of continuing to the right place. Does anyone know how to resolve this other than the linework tool? I've attached a Revit 2014 model to show what's going on.
    Thanks!
    Senior Member Darius's Avatar
    May 6, 2013
    501
    03:11 AM
    try using the start extrusion or end extrusion and make them postive number to extend the hollow core plank out
    cant really test this your central file is locked
    October 11, 2012
    St. Louis
    405
    12:11 AM
    Thank you that was more or less it, it was under the "Start Join Cutback" parameter. Any idea on why the central file was locked? I didn't know that was possible. I just saved out a portion of my model as a new central file before posting.
    May 6, 2013
    501
    03:11 AM
    i just opened the file from the site i should have downloaded and open and detached it from central and i would not have been locked
  1. holcon precast concrete floor and roof element
    By Bross in forum Rendering and Gallery
    Last Post: November 21st, 2013, 06:34 PM
  2. Precast Concrete Consturction
    Last Post: October 24th, 2013, 12:53 PM
  3. Precast stairs with ridges
    Last Post: May 31st, 2013, 09:21 AM
  4. Precast Wall Questions
    Last Post: May 9th, 2012, 08:43 PM
  5. Precast Component
    Last Post: March 9th, 2012, 02:08 PM
