Results 1 to 9 of 9
Thread: RSS Feed and Revit Communication Channel Compatibility
    April 21, 2011
    Oklahoma
    776
    04:04 PM
    Sadly, I must report that the RSS feed links for the Forums here on RFO are not compatible with the Communication Center RSS Feeds. Any thoughts on how to fix this? It's be nice to see new topics pop up.
    Kingdom of Denmark
    4,276
    12:04 AM
    Seems like the Com Center is looking for a feed in XML format, but for some reason the external.php?type=xml is not working... Good thing is that this does work: http://revitforum.org/external.php?type=rss
    Note: external.php?type=rss2 wont work in Com Center either...
    April 21, 2011
    Oklahoma
    776
    04:04 PM
    Hnnn... that URL seemed to work, but I haven't been able to get Com Center to recognize the feeds from individual forums sections (as opposed to the entire message board). Any thoughts?
    Alex Cunningham's Avatar
    Northern California
    3,576
    03:04 PM
    You have to find a RSS reader that is compatable with RSS2 format. Most will only read XLS. Maybe Munk can supply a RSS feed that is in the XLS format for the forum. I am not sure how it works on the domain side.
    Kingdom of Denmark
    4,276
    12:04 AM
    Quote Originally Posted by revittotd View Post
    Just suffix the above link with &forumids=X
    X being the Forum ID, e.g. http://revitforum.org/external.php?type=rss&forumids=2 for the "Revit Architecture and General Revit Questions"
    Kingdom of Denmark
    4,276
    12:04 AM
    Alex, the forum feeds provides us with: js, rss, rss2 and xml formats to choose from, and the rss type worked fine in the Com Center...
    I believe that XLS is used for spreadsheets BTW
    Northern California
    3,576
    03:04 PM
    On the main forum there is a small orange RSS button next to each sub forum. That button will send you to the RSS feed for this specific sub forum.
    Northern California
    3,576
    03:04 PM
    Bah!!! XML is what I ment.
    Kingdom of Denmark
    4,276
    12:04 AM
    Correct, but it links to the RSS2 feeds, so youll need to strip the "2" if you want to use it in the Com Center.
  1. RSS-feed all new posts
    By mdradvies in forum Forum Suggestions and Feedback
    Last Post: April 18th, 2011, 02:53 PM
  2. RSS Feeds
    By JCM in forum Out There
    Last Post: February 19th, 2011, 05:44 PM
  3. RSS Feed testing
    By Alex Cunningham in forum Forum Suggestions and Feedback
    Last Post: December 22nd, 2010, 10:42 AM
  4. Replies: 2
    Last Post: December 16th, 2010, 01:07 AM
