Thread: Roof partial overhang
    February 6, 2013
    11
    10:41 AM
    Hello people,
    I have a question about a roof of a shed. (See attachement).
    The shed has an existing part, and a part which is new to build.
    Now i want that the ridge of the new and de old roof is at the same place, but the overhang from the new part has to be longer.
    If you will look at the pictures i add you'll probably understand.
ID:	16010Click image for larger version.
    So the roof in the back is drawn good, with that overhang.
    But if you see the 2nd picture: The left part of that roof has to allign with the front part.
    I want to have one big roof, but the part left in the back has to have a bigger overhang than the rest of the roof
    I hope you people understand my question,
    Thanks for your help already!
    "OMG I killed Revit"
    dzatto's Avatar
    5,245
    04:41 AM
    You'll have to lower your eave height at the wall that sticks out past the other one. The height of that eave depends on the pitch of the roof and the offset of the wall.
    so, for example, if it's a 4:12 pitch and the wall is offset 2', lower that eave (sketch line) by 8".
    May 20, 2011
    Chicago, IL
    798
    05:41 AM
    or, you can use slope arrows (as per pic.) with the slope to match existing roof.
    Moderator mark b's Avatar
    NSW Australia
    1,434
    09:41 PM
    Simple way:-
    Roof by footprint / Extend into wall (to Core) + overhang.
    Just define the two walls of the short span and Revit will do the rest.
    If you want to opposite effect (cutoff span) just define the two walls of the big span.(image 4-5)
ID:	16014   Click image for larger version.
ID:	16015   Click image for larger version.
ID:	16016   Click image for larger version.
ID:	16017   Click image for larger version.
    May 20, 2011
    Chicago, IL
    798
    05:41 AM
    For single roof yes, but I think, the OP wants new roof to be attached to existing.
    NSW Australia
    1,434
    09:41 PM
    Quote Originally Posted by PijPiwo View Post
    Two single roof's just as easy,
    roof by footprint / extend into wall (checked) add wall return onto overhang but select shorter span wall (see image)
    or use slope arrows, (I try to avoid them personally)
ID:	16020   Click image for larger version.
    February 6, 2013
    11
    10:41 AM
    Hello guys,
    All of you thank you very much for takin time to explain!
    I'll try, and let you know what the result is.
    Thanks again!
  1. Partial ceiling demolition advice?
    Last Post: February 14th, 2014, 08:24 PM
  2. Constraining variable and partial arcs
    By jmk in forum Architecture - Family Creation
    Last Post: December 4th, 2013, 01:40 PM
    Last Post: September 18th, 2013, 01:15 PM
  4. Partial Room Color Fill
    Last Post: February 13th, 2013, 11:02 PM
  5. Partial slab demolition
    Last Post: July 12th, 2012, 11:19 PM
