Results 1 to 10 of 15
Thread: Recessed & Surface Y/N says Host <not associated>
    Member kirklyncox's Avatar
    February 7, 2011
    113
    02:02 AM
    Just out of curiosity I am wondering if someone could help explain to me what's happening here:
    I've started building some Face Based families that would have a Y/N Instance parameter labeled "Recessed". Then I use a simple Conditional Statement to drive a cut void into the Face of the host object to show as recessed, ie cutting a wall. Or toggle N to show as Surface mounted. The idea, one family to indicate an either/or condition when that's the only difference.
    I found when doing this the family loses its host when it become surfaced mounted (because the void is no longer cutting the face?). But when they are two separate families with the cutting void removed, then the Type Selector can be used to switch them out, which means more families to create and manage... not the end of the world but...just wondering...
    Recessed Surface - kirk.cox's library
    FB-Instance.rfa (has the Y/N toggle & cutting void)
    FB-Instance-Recessed.rfa (has the Y/N toggle forced to Yes & the cutting void)
    FB-Instance-Surface.rfa (has the Y/N toggle forced to No & the cutting void removed)
    Anybody else experience this?
    10,875
    04:02 AM
    I'm on my phone so I can't look at the attachments, but you CAN do it in one family without losing the host. Mine are done that way. Remind me and I'll send one tomorrow.
    February 7, 2011
    113
    02:02 AM
    Thanks Aaron. I'll hit you up tomorrow. I'm interested in knowing what I'm doing wrong here ...
    10,875
    04:02 AM
    It might be where the origin of the family is. Is the void cutting away the face where the Origin is, making it so there is no "face" there anymore?
    I'm guessing, of course. Talk tomorrow.
    10,875
    04:02 AM
    Yeppppp, so im completely wrong. Ours does the exact same thing as yours, and somehow we just havent noticed it. Whats odd, is it isnt the act of SWITCHING it that does it. Placing the "Surface mounted" TYPE on the wall also sets it to <not associated> which is odd, since you can obviously buidl a family thats face based that sits on the surface. Having the variable in there, with the void that moves on and off the wall, appears to "mess with something."
    August 19, 2011
    New Hampshire
    513
    05:02 AM
    My fix for situations like this is to turn the void into a 1/32" cube so that it still cuts the surface but is (should) be hidden by the line thickness of the wall.
    February 7, 2011
    113
    02:02 AM
    Yeah, I considered that, too. I'm thinking, what's the lesser of two evils? ... Hmmm
    December 20, 2010
    1,115
    05:02 AM
    Try using a parameter that moves the void away from the face when you want 0. I didn't try it on a FB but i used to have columns set up for whole, half, and corner and we used a void that would move away from the column based on what type you wanted. This gets around the something can't be 0 problem.
    10,875
    04:02 AM
    That's how ours/yours are, Scott. The void moving seems to cause the issue.
    November 27, 2013
    47
    05:02 AM
    Sorry for the Thread Necromancy, but did you ever work out a work-around for this by any chance?
  1. Wall clean up - recessed panel
    By Number 7 in forum Architecture and General Revit Questions
    Last Post: June 14th, 2014, 07:26 AM
  2. Recessed Baseboard
    By sspringer11 in forum Architecture and General Revit Questions
    Last Post: November 14th, 2013, 10:58 PM
  3. Revit OpEd: To Host or Not Host
    Last Post: December 16th, 2011, 09:15 PM
  4. Recessed lettering
    By Defiant1 in forum Structure - General Questions
    Last Post: September 9th, 2011, 08:03 AM
  5. Recessed Ceiling
    By dlggnation in forum Architecture and General Revit Questions
    Last Post: May 23rd, 2011, 06:24 AM
