Thread: tag for footing, pier and column in one line
    November 28, 2011
    Ontario, Canada
    154
    07:30 PM
    Hello All
    I have created some new tags for footings, piers and columns based upon a number. An example would be F1, P1, C1.
    I am kind of getting stumped, as I would like to have the tags be in one line and I was hoping if someone could guide me in the right direction.
    periodically we have projects that we will only have two or three footings, piers and column and rather than placing text I want to use a tag. The tags will then be called up on a schedule. I have generated the schedules and they are working correctly at the moment.
    Thanks in advance.
    Kevin
    6,389
    07:30 PM
    Do you want the tags to align or all of the information in one line in a single tag? I don't think you can do the latter. Reason being: A column, footing and pier are all separate objects and have different tag categories. You might be able to do it using a multi-category tag but it would take some gerrymandering to get the data to push through.
    If you just need them to align it's just one of those things... tags from different categories have iffy alignment properties and don't always snap to one-another. http://www.revitforum.org/architectu...ning-tags.html
  1. Circular Architectural Column - Join Line Issue
    By MartinGT in forum Architecture - Family Creation
    Last Post: June 12th, 2013, 08:44 PM
  2. Step Footing modeled in place, hidden line how to?
    By Lauren in forum Structure - General Questions
    Last Post: June 4th, 2013, 02:00 PM
  3. Offset Vertical bracing (steel plates) from center line of Column
    By Ed_Ferreira in forum Structure - General Questions
    Last Post: February 12th, 2013, 07:11 PM
  4. Column & Footing Rebar Graphical Schedules
    Last Post: February 15th, 2012, 12:40 AM
  5. Stepped footing not joining with Wall footing
    By AHutchinson in forum Structure - Family Creation
    Last Post: February 14th, 2012, 06:52 PM
