Thread: Do you save a generic family set o Struct framing as framing member or as Component
    March 21, 2011
    Brisbane
    290
    05:36 PM
    Do you save a generic family set o Struct framing as framing member or as Component in your library
    Hi
    If you create a new family using a Generic Family but change it to a Structural Framing ľ do you save it and name it as Structural Framing member or as a Loadable Family in your library?
    The reason I ask is when you place a framing member you expect a certain behaviour from it ie it has an end and start point while some generic components might not.
    I hope it make sense
    Cheers,
    J
    Alex Cunningham's Avatar
    Northern California
    3,574
    11:36 PM
    If you want the family to work as a framing member start off making the framing member with the correct template. The changing of category will not give you all the needed items with in the family to make a fully functioning framing member. Compare the Generic Family to the Structural Framing Family. You will see the differences.
  1. Symbolic Lines in Framing members
    By Lambolica in forum Structure - Family Creation
    Last Post: May 18th, 2011, 04:34 AM
  2. Framing Plan/ Visibility Graphics
    By iitdesigner in forum Architecture and General Revit Questions
    Last Post: April 18th, 2011, 02:15 PM
  3. Detail Callout on Framing Elevation?
    Last Post: March 14th, 2011, 08:48 PM
