Thread: Curtain grid based elements cannot be grouped.
    Member Cyus's Avatar
    July 10, 2012
    UK
    499
    08:52 PM
    I have no curtain grid based elements (curtain walls?) in the project. This error occurs when I'm attempting to change the phase of a wall in a group from proposed to existing. I get this error when attempting to close the group, and it only seems to occur when changing the phase of elements that have been demolished in another group instance. However, I'm not sure what that has to do with curtain grid based elements. o.O
    Has anyone come across this before?
    6,398
    03:52 PM
    Is it a stacked wall?
    July 10, 2012
    UK
    499
    08:52 PM
    Nope. Just a standard partition. Nothing different to any wall I've used before.
    I've also managed to generate (and fix) an "Element's internal join data is corrupt." error. On a wall. Not sure what I'm doing wrong today.
    R.I.P. MPwuzhere's Avatar
    Las Vegas, NV
    4,864
    11:52 AM
    Is there a window in the wall that is created from a curtain wall?
    July 10, 2012
    UK
    499
    08:52 PM
    Nope. Haven't used curtain walls or any curtain panels at all on this project. Although it does seem to affect walls that have doors in them.
    2,889
    05:52 AM
    Is this happening to all your walls or just the one in the group? Have you tried removing the affected wall from the group, then changing the phase? Groups can get weird and sometimes hang on to legacy stuff.
    July 10, 2012
    UK
    499
    08:52 PM
    Demolishing elements using the hammer outside of group edit mode seems to bypass the problem.
  1. Odd (new?) Curtain Panel/Grid V/G observation
    Last Post: January 9th, 2014, 05:51 PM
  2. How is Generic Model Pattern Based different from Curtain Panel Pattern Based
    By shtirlits in forum Architecture - Family Creation
    Last Post: October 5th, 2012, 12:14 AM
  3. Creating a 45 degree curtain grid
    By aaronlo11 in forum Architecture and General Revit Questions
    Last Post: September 28th, 2011, 02:38 AM
  4. Curtain Grid.
    By houshmand81 in forum Architecture and General Revit Questions
    Last Post: August 19th, 2011, 03:29 PM
