Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 38
Thread: My renderings
  1. #11
    1,634
    02:15 PM
    Quote Originally Posted by kowen1208 View Post
    I'd also consider putting something like a task light on each desk.
    Nope, boss will have me take those off there, as they are not part of the project and will not be on the desks when the project is done, meaning that every part of this render (up to the sprinkles) will be there IRL life too.
    The green wall to the back-right is LOUD. Could be because of cloud rendering instead of local.
    Think that is indeed better when I render it local, but I will have to check.
    The floor still looks like a sheet good and not a plank.
    Have a nice texture and a bump, just need to play with the settings a little on those.
    The spacing on the ceiling is as it should be, pretty close to eachother, so yes it does seem heavy at the back, but that is how it will look IRL as well I suppose.
    Anyway, thanx for the replies people, will do some more tweaking when there is time
  2. #12
    1,634
    02:15 PM
    Well the office project is done and did not do much render work at the office.
    I did however did a design of my own future kitchen. Tiny space so had to cramp stuff in there a bit.
    Still needs some decorations and colors here and there, but thats the start.
  3. #13
    1,634
    02:15 PM
    Just remembered I did a few a while back. It is mostly just the buildings and no surroundings, but still pretty nice I think
ID:	19648   Click image for larger version.
ID:	19649   Click image for larger version.
ID:	19650   Click image for larger version.
  4. #14
    6,387
    08:15 AM
    Where did you get the wood texture in the last image?!? I like!
  5. #15
    "OMG I killed Revit"
    dzatto's Avatar
    5,275
    07:15 AM
    I think it's an OOTB revit material. I use the same one for wood fences and gates.
  6. #16
    1,634
    02:15 PM
    It is called Wood-texture-by-yasse-inne-on-deviantart 01.jpg and I got it from Devianart, where it now is not anymore.
    But I still have it, see attached. No bumpmap though.
  7. #17
    1,634
    02:15 PM
    Well, another little ting I have been playing around with. Doing better grass as we speak and also the dirt needs to be a bit better. I'm guessing the transition between dirt and grass is something I would have to do in photoshop.
Name:	3D View 7-4.jpg
  8. #18
    6,387
    08:15 AM
    Looking good.
    The transition between the grass & dirt could be done a number of ways depending on what you want it to be. A border could be modeled pretty easily with a sweep or a few families.
    One question - what is going on with the glass under the arch (see attached?)
  9. #19
    1,634
    02:15 PM
    Well, I have glass that has a bit of a wobbly reflection, as the OOTB glass reflects everything straight and I usually don't like that and IRL that does not happen either. I agree this might be a bit much. Then again I use the same glass at the other elevations, so maybe this is becasue I have a glass wall on the inside too and the reflections is a bit weird because of that??
    Don't think there will be an actual border there, just the grass going over into dirt where the grape vines grow.
  10. #20
    Member TheRevitKid's Avatar
    May 22, 2012
    Connecticut
    185
    08:15 AM
    Hmmm... That glass bump looks familiar...
    http://therevitkid.blogspot.com/2013...change-to.html
    I would turn down the bump a tad... It does have the ability to get out of control!
  1. my renderings
    By cymemont in forum Rendering and Gallery
    Last Post: February 13th, 2013, 08:47 PM
  2. Renderings for your critiquing
    By unraw in forum Rendering and Gallery
    Last Post: December 14th, 2012, 03:46 PM
  3. ISOMETRIC Renderings
    By viola23 in forum Architecture and General Revit Questions
    Last Post: November 25th, 2012, 12:36 PM
  4. Renderings For your comment
    By sdbrownaia in forum Rendering and Gallery
    Last Post: October 23rd, 2012, 11:16 PM
  5. Exterior Renderings
    By dzatto in forum Rendering and Gallery
    Last Post: August 31st, 2012, 03:27 PM
