Results 1 to 9 of 9
Thread: is revit capable of hifalutin design?
    May 23, 2011
    15
    07:04 PM
    what i specifically mean is that, is revit capable of modeling biomorphic designs? i'm wondering whether it can make models similar to zaha hadid's and frank gehry's designs, while utilizing its BIM capability. my knowledge in revit is only at the beginners level because i have started just recently and i used to model in 3ds max. but i think BIM is a powerful tool especially for the architects.
    Member rosskirby's Avatar
    Marietta, GA
    139
    06:04 AM
    Yes. You'll have to model the overall shape as a conceptual mass, import that into the project file, and there you can apply walls/floors/roofs/curtain walls/ceilings/etc. to the mass.
    April 21, 2011
    Oklahoma
    776
    05:04 AM
    Take a look at Zach Kron's blog over at http://buildz.blogspot.com/ I think you'll find this a satisfactory answer.
    May 23, 2011
    15
    07:04 PM
    Quote Originally Posted by revittotd View Post
    wow! those are really advanced techniques and i'm convinced. do i need any plug-ins in order to do that or that is possible even for out-of-the-box revit?
    December 17, 2010
    Pembroke Pines, FL
    571
    07:04 AM
    Thats all out of the box, except for the physics simulation stuff which is done in Vasari.
    St. Louis, MO
    1,961
    05:04 AM
    check here also:
    http://www.youtube.com/watch?v=p4xY7W795FE
    http://www.youtube.com/watch?v=qjIqU...DE576&index=18
    http://designreform.net/
    also attached a couple of our projects done in Revit.
    enjoy............
Name:	3D View 2-Sunrise.jpg
ID:	2294   Click image for larger version.
Name:	Exterior Rendering View Final.jpg
    April 21, 2011
    Oklahoma
    776
    05:04 AM
    Quote Originally Posted by JCM View Post
    *merrrrrrrrr* nope. You can now do that with the Nucleus Revit plugin inside of Revit's CDE
    Thanks for playing tho! :cheers:
    December 17, 2010
    Pembroke Pines, FL
    571
    07:04 AM
    I had some doubts when posting, I get those confused all the time. Thanks for the clarification though!
    11:04 AM
    Quote Originally Posted by rosskirby View Post
    Well, I have to make some remarks on this statement. Yes, it's possible. BUT their are some major backdrafts to using double curved surfaces in Revit.
    The problem with all those (extremely awesome) Buildz blog posts and examples is this: it ends with the form.
    When using double curved faces in Revit is the next stage in Design, the documentation. You will want to go to annotated drawings at some point in time. This will give you a lot of .
    I once did a project for a museum based on catenaries. The mass could be modelled but Mass Floors didn't work. Neither did Volume and Area computations of the faces. I couldn't use the Pick Line/Wall tool to model Ceilings, Floors or that kind of stuff. Creating the buildings skin was problematic: Roof by Face didn't work due to problems with the Roof Edge settings. Using Walls would only work until a certain thickness, etc, etc.
    So it can be done, but remember that it will take some effort
Name:	2010C-006 Paviljoen.jpg
  1. Design Review in Revit
    By mdradvies in forum Coordination Tools
    Last Post: January 9th, 2013, 08:06 PM
  2. Design Review
    By gdoherty0102 in forum Coordination Tools
    Last Post: January 9th, 2013, 07:32 PM
  3. Demolition and Design Options
    Last Post: May 24th, 2011, 05:58 PM
    Last Post: May 16th, 2011, 07:25 PM
  5. Design Options
    Last Post: May 4th, 2011, 02:24 PM
