Thread: 2013 "failed to apply family parameters"
    Junior Member Arno's Avatar
    August 29, 2011
    Schoorl
    45
    11:15 AM
    Question 2013 "failed to apply family parameters"
    I have made a door familie (origine generic model).
    Now I want to make a curtain wall panel from it. So i copy the geometric to the curtain panel family. No problem so far.
    But when i try to add a parameter i get the following error: "failed to apply family parameters" (doesn't make a difference if it is shared or not)
    When i remove the geometrie there is no problem. But when i add the the geometrie again the parameter won't flex.
    Same error. Why isn;t this posible
    copy geo family - Arno_Screencast's library
    August 19, 2011
    New Hampshire
    513
    04:15 AM
    Did you unlink parameters from the geometry you're copying to the curtain panel family? If you didn't, the geometry still believes it's being controlled by parameters that don't exist in your new family. That's why you're seeing that error.
    2,719
    07:15 PM
    Good call Andrew. I've mostly found that, although copy paste is tempting, biting the bullet and recreating geometry usually works best.
    August 29, 2011
    Schoorl
    45
    11:15 AM
    Even if i delete all parameters it is still giving the error.
    We will remodel, hope autodesk will look into this.
    August 19, 2011
    New Hampshire
    513
    04:15 AM
    You don't have to delete the parameters themselves. Was any of the door geometry controlled by material parameters or visibility parameters? Normally dimension parameters don't get carried over if you copy/paste, but material and visibility usually stick. Click on your extrusions and see if any parameters are greyed out when they shouldn't be.
    R.I.P. MPwuzhere's Avatar
    Las Vegas, NV
    4,864
    01:15 AM
    Could help to post the family too....
  1. What "categories" to put parameters in families?
    By iru69 in forum Architecture - Family Creation
    Last Post: July 13th, 2017, 07:06 AM
  2. Door Family template - how to delete "pre defined" parameters (or change them)
    By Hilife in forum Architecture - Family Creation
    Last Post: April 23rd, 2013, 05:48 PM
  3. Family Type Parameters and "Export Family Types" functionality...
    By Twiceroadsfool in forum Architecture and General Revit Questions
    Last Post: September 7th, 2011, 08:05 AM
  4. "This product failed to uninstall."
    Last Post: May 18th, 2011, 05:06 PM
