Thread: Detail Item Not Flexing in Family
    March 9, 2014
    59
    01:26 AM
    Hello Everyone,
    I am creating a door family with nested swing lines. The swing lines are parametric and flex perfectly fine, but when I load them into the family they will not flex. I have them locked to corresponding references too, any ideas what I'm overlooking? I greatly appreciate the feedback!!
    Thanks!
    2,765
    03:26 PM
    Have you linked your nested parameters through to the parent family parameters or are you making changes through 'edit type'?
    March 9, 2014
    59
    01:26 AM
    How do I link them? I have just been trying to flex it using other parameters that I created in the parent family. The nest parameters are not showing up in the parent family.
    2,765
    03:26 PM
    Select the instance of your nested family then where I have highlighted in yellow on the attached PP image press this button to link to your parent family parameters. Type parameters you'll need to hit 'edit type' first.
    Then you can control them from family types Name:  Capture.PNG
    March 9, 2014
    59
    01:26 AM
    Wow thanks so much!! I really appreciate your help!!
  1. Movable Label Annotation in a Detail Item Family
    By SamHenderson27 in forum Structure - Family Creation
    Last Post: December 15th, 2019, 08:22 AM
    Last Post: January 29th, 2014, 01:15 AM
  3. Tagging a single item in a detail component
    Last Post: January 7th, 2013, 11:34 AM
  4. Default Detail Item Tag
    By RodneyLester in forum Architecture and General Revit Questions
    Last Post: March 8th, 2012, 03:03 PM
  5. Titleblock vs Detail Item
    By jsnyder in forum Architecture and General Revit Questions
    Last Post: February 8th, 2011, 10:48 PM
