Thread: Extensions - base plate placed at top of column!
    April 9, 2014
    Glasgow
    06:35 AM
    For some reason revit extensions steel connections function has decided to place the base plate at the top of some of my columns. I've checked the properties of the columns and all settings when placing but can't figure out why. I can manually reassign the work plane but this is time consuming and I'd like to figure out why this is happening. Anyone else had the same problem? (I've also had a similar issue with beam-to-column connections with haunching and plates facing the opposite direction)
Name:	Base Plate at top.JPG
    April 14, 2014
    74
    01:35 AM
    I'd guess it is because when the columns were first modelled they were done with a depth rather than height. Once done this way I am not sure it can be changed. Just a guess. Try some tests and see.
  1. Revit 2014: Wall join to Column overides column display
    By MrBIMtastic in forum Architecture and General Revit Questions
    Last Post: June 20th, 2015, 12:09 AM
  2. Column Base plate
    By jean_francois_nant in forum Structure - General Questions
    Last Post: December 9th, 2013, 04:12 PM
  3. Elevation not showing properly in my custom base plate tag.
    By cordell in forum Structure - Family Creation
    Last Post: November 19th, 2012, 02:55 PM
  4. Column Base Plates
    Last Post: February 16th, 2012, 09:14 PM
  5. Pier and Base Plate Plan details
    Last Post: January 19th, 2012, 10:29 PM
